1939 Chevrolet 85 master gas tank
Hi guys, does anyone know what kind of doner car I could use for a gas tank. My options are limited due to me being in New Zealnd. The cars here are mainly Japanese and some British. I am looking for something with a larger fuel capacity than the original gas tank. Any thoughts?
High-Density Polyethylene - Heavy Wall Construction Patented Baffle - Tunnel - Minimizes Sloshing Pickup Tube & Vent - Top-Mounted as Required by the Federal Code of Regulations Fuel-Proof Connecting Hose Neck in Stock Location - Does Not Require Trimming the Inner Fender 1 -7/8" Deeper Than Stock - 17 Gallon Capacity 36 x 16 x 9 Accepts All 5-Hole Senders - VDO, SW, Classic, etc. Galvanneal Straps T-Bolts Available I understand you are a long way from the USA ... but there is a company here that makes replacement tanks ... ( the one above ) for $219 US ... http://www.tanksinc.com/index.cfm [B] In the long run ... it may be more economical to just buy a new one and have everything fit right than spending $$$ on trying to make something work that is already older and used ... then cut and modified ... Just my nickel ... Deuce ... Moderator |
Thanks very much for the help will look into this ( Cheers )
1939 chevrolet gas tank
Thanks to all who have sent me info. This web site is brilliant.All the tips I get from you all are saving me a lot time in my build Once again many thanks.
This is a bit off topic, but with the problems you fellows down under have getting after market parts, why doesn't Summit, Jegs, etc., open some stores over there? Dan
| Recent General Rodding Tech posts with photos |
| 1939 chevrolet master sedan delux | pudsey66 | Hotrodding Basics | 8 | 04-17-2006 11:44 PM |
| 1939 85 Master Deluxe Chev | pudsey66 | Introduce Yourself | 2 | 04-14-2006 01:25 PM |
| gas tank pressuring up | montea | General Rodding Tech | 3 | 06-04-2004 08:37 PM |
| diesel in gas tank help asap | mike69scj | Engine | 15 | 05-30-2004 09:52 PM |
| Torino wont stay running | 79firebird350 | Engine | 4 | 05-20-2004 12:38 PM |
