1939 Ford Deluxe Coupe doors - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2002, 09:17 AM
Post 1939 Ford Deluxe Coupe doors
Does anybody know if the doors on a '39 Ford Deluxe Coupe or Sedan the same as a '40?
Thanks!
Old 06-11-2002, 09:25 AM
Post
I believe they are, but I am not 100% sure.The bodies didn't really change much except for the grill is a little different.
Old 06-11-2002, 02:12 PM
Talking
CARGUY, THE DIFFERENCE IS IN THE VENT GLASS. 39 HAS NONE. SEDAN AND COUPE ARE NOT THE SAME, SEDAN IS ABOUT 8" LONGER. YOU CAN SWAP BETWEEN THE YEARS, AND MANY GUYS HAVE ELIMINATED THE VENT WINDOW ON 40'S. HINGES AND LATCHES ARE THE SAME. THERE IS A DIFFERENCE IN STAINLESS TRIM, HOWEVER I AM PRETTY SURE HOLES ARE THE SAME, I COULD CHECK THIS IF YOU NEED TO KNOW.GOOD LUCK.
Old 09-14-2005, 06:00 AM
primerat's Avatar
New Member
Last journal entry: GAS PUMP
doors
The fordor sedan door will work on the coupe, you just have to trim the top corner. 39/40 are interchangable with minor work. Thanks AL
Building a 1932 5 Window Ford Coupe 32FordVA Introduce Yourself 3 01-28-2006 04:38 PM
36 Ford Coupe Advice dhinrichs47 Hotrodding Basics 8 01-25-2006 08:02 AM
My 35 ford coupe gunnulf General Rodding Tech 7 11-03-2005 10:55 AM
ford 35 coupe gunnulf Hotrodding Basics 2 09-19-2005 04:27 PM
1930 Coupe Doors? SuperFrog Body - Exterior 3 03-06-2004 04:53 AM
