1939 ford flathead need help!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2008, 04:33 PM
i'm having a hard time getting a hot fire at the coil wire, i got a new 6-volt coil, set points at .17, got 6-volts going to the + side of the coil, has small spark but not enough to fire a spark plug.
Old 11-22-2008, 06:51 PM
justold's Avatar
you didn't mention if it is 6 or v8 .If it is a 6 the points should be set at .025" a v8 has duel points and and should be set with a degree wheel or on a dist. machine , also you didn't say weather you installed a new condenser.
Old 11-23-2008, 08:11 AM
Frisco's Avatar
Glad To Be Here
The '39 Ford flathead was 6 volt with positive ground. You have the coil wire reversed from what it should be. The wire coming from the ignition switch should be connected to the (-) terminal of the coil. The wire from the coils (+) terminal will then go to the distributor. Replace the condenser. Cheap to replace and will make a major difference if the one in it now is bad. The point gap should be .016-.022. For new points set them at the .022 setting as the fiber pad will wear down fairly quick during the first 1000 miles. Plugs should be set at .025.
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
T-5 Transmission To A Flathead Ford V /8 1948, Late Model DMMARTIN Introduce Yourself 3 12-06-2006 09:29 PM
i need ford flathead block ajcedar Engine 1 07-13-2006 01:07 PM
Ford Flathead to Ford automatic c4-kit? bigjim Engine 4 01-05-2005 02:11 PM
Best street/strip cam for ford flathead V8's?? '54-Hunter Engine 2 02-05-2003 10:15 AM
