1939 Plymouth - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2011, 10:31 AM
1939 Plymouth
Hey out there!
I have a 1939 Plymouth that I want to remove the body from the chassis.
My question is do I need to remove the steering box and column from the bottom then raise the body? Could I cut the column and then install a coupling later?
Scholman
Old 07-25-2011, 01:29 PM
boatbob2
removing body.....
HI,instead of cutting the steering column,why not just disconnect it? i removed the body on my 48 ford coupe,by disconnecting everything,then using a 4 ton engine hoist,BUT,my interior,doors,front and rear fenders and hood and trunk lid,were taken off first
Old 07-25-2011, 05:29 PM
boatbob2,
I can not lift the body that high. I have a single story garage so I can lift the body off of the running gear by about a foot. Then roll the chassis out from under the body. The column is about three feet above the floorboard so to clear it I would need to raise the body at least 4 maybe 5 feet above the column. On older trucks I know the entire column and steering box are removed as a unit and lowered to the ground getting the clearance needed to remove the body. So I am thinking I will need to do that also.
Scholman
Old 07-25-2011, 08:10 PM
Wiki Edits: 27
meat cleaver time ?
unbolt it , take off the steering wheel and let it roll foreward, have the gear on the ground tied with a wire to keep it with the frame
1939 Plymouth Headlights; Halogen Replacements and Missing Sockets hduff Electrical 5 02-12-2008 10:30 AM
Newbie rebuilding a 1939 plymouth Petes 1939 plymouth Introduce Yourself 2 10-15-2006 11:13 PM
Retro-rod - 1939 Plymouth Business Coupe ply39 Hotrodding Basics 11 07-09-2006 11:09 PM
1939 Plymouth 5 window coupe conversion 39Plymouth Introduce Yourself 3 12-30-2005 07:55 PM
1939 plymouth fenders plymouthrules Body - Exterior 1 02-17-2004 10:38 AM
