1940 Chevy Coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2013, 09:57 AM
1940 Chevy Coupe
Will the a frame off a 80s s10 work on a 1940 Chevy coupe
Old 06-02-2013, 10:13 PM
Sure. As long as you are willing to cut the whole floor out to channel it about 6" over the frame. And loose the back seat and most of the trunk since the frame is in the way. And convert the S10 to rack and pinion since the steering sticks out further than the front fenders.
Old 06-03-2013, 09:18 AM
kso's Avatar
kso kso is offline
Lol. What's being said here is that it's a poor fit. Up front, the '40 has very little space between the axle center and the grille, the steering box from the S-10 would be sticking out the front. In the middle, the S-10 frame kicks up right behind where the cab would be and accommodates a long fuel tank which is perfect for a truck but, in the '40, that needs to be passenger space. Guys use S-10 frames in old pickups and other than the fact that the front track is a bit narrow and it's a tight fit for a V8, it works OK.
I have a friend who used a perimeter-type GM passenger car frame on a '40. I don't know why he got so stuck on doing that, if fit like crap also.
Really, there is no better-fitting frame for your '40 than the original one, which has the right shape and body brackets there already. There may be aftermarket ones built with that same shape to fit if you got the bucks, or you could toughen-up and update your original.
Again, back to what it is you're dreamin' of, you-know. Either way and whatever you do, once you get that figured out it's going to be some work.
Old 06-03-2013, 09:51 AM
Thanks for the info kso it was helpful
Old 06-18-2013, 08:51 AM
This is really on the money, unless you plan on going to an aftermarket 35-40 Chassis, the best bet is to stick with the original chassis and have it worked up for what you want be it IFS and disc or straight axle. Contrary to popular belief... with the aftermarket components available today there are not many applications at all where a later model vehicle frame swap is advantageous, cheaper or better.
Old 06-18-2013, 08:59 AM
I understand and believe what you are saying. Even more when labor rates are involved. What about using the s-10 front clip only with the rack. It would appear to me this might be a very economicaly route for the home builder.
Is it a practical route?
What are the issues making a r&p work with the s-10 clip?
John
Old 06-18-2013, 09:56 AM
Personally my opinion here but myself, I would actually install a drop straight axle incorporate a good shock and add some castor to it before I clipped it with an S-10. Again... just my personal opinion... As far as the R&P on the S-10, I have never really looked at putting one on an S-10 front suspension so I do not know what kind of Ackerman or bump-steer issues you might get.
1940 Chevy coupe slaminwagon Introduce Yourself 1 12-28-2011 03:23 PM
1940 Chevy Coupe CHASINGJR Introduce Yourself 9 11-10-2006 06:07 AM
1940 Chevy Coupe? ClaytonStewart Introduce Yourself 3 05-02-2006 10:35 PM
1940 Chevy Coupe fastco Body - Exterior 6 01-10-2006 07:33 AM
1940 Chevy Coupe mecjac Hotrodding Basics 4 12-10-2004 06:52 AM
