1940 Chevy Coupe Engine Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2006, 11:39 PM
What does it take to drop a 350 CSB/350 trans into a 1940 Chevy Coupe? What types of engine/transmissions mounts are recommended, crossmembers if needed? Parts sources?Not looking for fancy just functional. Any help greatly appreciated.
Old 01-28-2006, 06:02 AM
Chassis Engineering sells most everything you need......
http://www.chassisengineeringinc.com/
As a moderator here, I would like to WELCOME YOU .. to Hotrodders.com
We have a lot of members who are into early Chevrolets and many more with a vast knowledge of most things mechanical. Again....Welcome
Deuce
Old 01-28-2006, 07:11 AM
40bowtie's Avatar
I would go with what you see in the picture that Deuce posted. Myself I made my own. Thats up to you. For the trans I used a stock Camaro mount from around 1980. I just welded a tab with a hole in it to the rear side of the cross-member. IM sure you know that you will need to cut the tunnel and fab a new one to get the bell of the tranny under the firewall.
Old 01-28-2006, 10:14 AM
Thanks for the help guys!
Kind of new to this. Is there a need for a cross member or only if I go to an IFS system? I'm looking to do the engine swap first and maybe down the road, as funds become available, upgrade the suspension. Is this approach feasible?
Old 01-28-2006, 02:45 PM
40bowtie's Avatar
Your lucky on the 40 because the stock crossmember bolts in. When I first started mine I left the stock suspension for a few years. I hated it, but I was able to drive it. Not far. My arms would get sore. I then added a crossmember with a mustang 2 suspension. I bought a crossmember and welded mine in. Ta do this I pulled everything from the F-wall forward. Not long after I found a place that sold a crossmember that would bolt in place of the old one. That would have saved alot of extra work. I think it was from Fatman, but I would have to look it up to make sure.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
1940 Chevy Coupe fastco Body - Exterior 6 01-10-2006 07:33 AM
8.1 marine spec engine swap into a 57 chevy pickup customike Engine 2 12-03-2004 11:19 PM
1940 Chevy coupe ,body & trim & bumpers fastco Body - Exterior 1 08-12-2002 08:41 PM
