1940 Chevy Coupe Transmissions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2006, 10:42 AM
Hey all, Does anyone know what crossmember work is require to get a TH400 is this car? Can the original crossmember be modified and reused or does it have to come out completely? How much drop is needed to clear the floor pan? Any aftermarket crossmember recommendations? Any help greatly appreciated.
Old 11-06-2006, 11:50 AM
Why a Turbo 400 ??
I have one in my 32 ... but a Turbo 350 is smaller and lighter. Takes less horsepower to turn also. If I was building a new car ... I would look at a automatic OD transmission ...
I believe the 700R4 would be worth the effort to install ... especially this early in the build. That's what I am using in my new car.
Deuce ...
Old 11-06-2006, 03:37 PM
Last journal entry: It's getting there
I agree with Deuce. I have a '41 Chevy Coupe and put a 700R in for that very reason (Fuel Economy).
I am pleased with the results, as it is a Crusier and with fuel prices the way they are, I cna at least control some of the cost of operation.
Old 11-06-2006, 07:28 PM
Wiki Edits: 49
A reverse "K" member used to be available from Butch's Rod Shop to mount a TH-350/400 but I'm not sure Butch's is still in business. Had one in my pro-street 41 and it worked very well. Do a search for Butch's Rod Shop and you can find contact information. There is no web site currently which makes me believe they're out of business now. I could be wrong though.
Old 11-06-2006, 09:24 PM
1940 Chevy Transmission
Thanks for the feedback! Actually I'm not set on installing the TH400 I just happen to have one and since I'll be running a bbc I thought it might be a nice match. I am however also considering the TH700 as the motor is not going to be a high power unit. Does anyone know how much drop I will need to clear the floor pan? I'm only looking to replace the tunnel cover with an after market. I really don't want to do a bunch of fire wall/floor pan cutting and fabrication, just not that good at it.
Old 11-06-2006, 09:32 PM
The tranny won't be your problem. Where you might run into a problem is at the firewall if you use an HEI that sits too high. Mine is pretty close. I just installed the MDS Streetfire. They do make a low rise cap that will work.
1940 Chevy Coupe Tire/rim sizes canyonclimber General Rodding Tech 3 08-04-2006 06:52 AM
New Member w/1932 Chevy Coupe Project devilstrip Introduce Yourself 2 07-14-2006 12:09 AM
1940 Chevy Coupe fastco Body - Exterior 6 01-10-2006 07:33 AM
1940 Chevy Coupe mecjac Hotrodding Basics 4 12-10-2004 06:52 AM
1940 Chevy coupe ,body & trim & bumpers fastco Body - Exterior 1 08-12-2002 08:41 PM
