1940 chevy headlites on 1939 Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2011, 07:40 PM
Carpoor's Avatar
Looking for help on installing 40 chevy headlites on my 39 Chevy, Seen several 39s done this way. Fit is close as is, just looking for a few tips for a perfect fit. Thanks
Old 04-26-2011, 08:15 AM
I did this on my 39. Since I wanted it to match the fender perfectly I cut out the original mounting plates on the 40 buckets and then welded in new ones after the buckets were fitted to the fender. In order to do this I sliced the 40 buckets lengthwise on the side that faces the hood and moved the bottom of the bucket to match the fender and added filler material to the bucket. I also added material under the area where the headlight meets the fender. There might be an easier way but that is what I did.
Old 04-26-2011, 10:13 PM
Carpoor's Avatar
Thanks Andy, I have removed most of the front mounting plate, so maybe I am on the right track. Kinda scary cutting on buckets, but i will get there one way or another. Thanks for the help.
1939 Chevy avila39 Body - Exterior 0 02-25-2011 11:34 AM
1939 chevy Retsfc7 Introduce Yourself 1 01-27-2011 03:39 PM
40 chevy headlites on 39 fenders andymac Body - Exterior 0 05-01-2008 07:44 AM
1939 / 1940 Ford Sedan Top Chop Sparkplug1939 Body - Exterior 2 06-19-2005 09:04 AM
1939 Chevy Fenders dant Body - Exterior 5 05-20-2005 10:43 AM
