Hello hotrodders
I'm putting together a 1940 Chevy 1/2 ton truck and will put in a mII front end.
I'm not to sure which company to use and weather to use a power rack or not.
Ive been thinking that The truck with a small block etc. wont weigh that much so a power rack wont be needed.
What MII system would you recommend?
Thanks.
I have dealt with Chassis Engineering with great success, as a lot of my friends, have also. Good Company to deal with.
If you are putting in Sm. Blk. Chevy. I don't think you will need Power Rack, as the M 2 sits out futher, as to take weight off of front end. Now maybe if a lady is driving it, possibly you might need it. B B is a little heavier, and would be best to use a Power Rack.
If money is tight, I have used Pinto, about same as M 2. The Pinto I used, was one off of a decent Pinto, spent a lot of time on cleaning it up, in order to be able to weld in.
Another one is a Volare, but they are hard to find. I believe the bolt pattern is same M 2.
Check on line to see the best price for name brand, Fat Man, Chassis Eng.; Heidt's, and ECT. There are some newer companies out now, but not to familiar with them.
The Filling Station specializing in Chevy. & GMC parts. www.fillingstation.com
Cruise On. :thumbup:
You can buy a complete unit or a weld-together unit, the choice is yours, based on your mechanical ability.
I like the M2 front end because the Granada 11 inch rotors, Camaro calipers and hoses, just make it so right.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
