1940 chevy truck sbc engine placement - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2012, 06:10 PM
Hi guys and gals.
I have the frame almost boxed in. what i need to figure out is how far back the engine should be from the rad?
i want to put in the motor mounts and trans mounts.
I'm not to sure where it should go.
Any suggestions?
Thanks in advance.
Barry
Old 03-21-2012, 08:10 PM
The #1 spark plug should be at or behind the centerline of the front wheels(axle) Farther back makes for better balance but not so much that I would butcher a good firewall for a couple of inches, especially for a street rod. You also want to make sure the distributor and bellhousing clear the firewall and fit the tunnel. Put the engine on a hoist and roll the chassis/cab under it and set it as far back as practical then see where you are with the front, then let us know.
Old 03-23-2012, 07:33 PM
if it will help I can take measurements on mine and post photos....
My number one sets just behind the centerline, the mustangII crossmember is under the front most of the oil pan and my rack n pinion is under the harmonic balancer....
Old 03-23-2012, 07:43 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
the best way is to swing it in there (as far back as you can) and thats where it goes
no guessing
Old 03-24-2012, 11:01 AM
I had one fella with an identical truck with a 327 and he measured 10" from rad to front of heads.
I was thinking 6" from rad to front of short water pump.
It should be in the ball park.
I dont have the cab handy to put on the chassis, thats why i asked for a measurement.
Thanks for the help guys.
Barry
Old 03-25-2012, 08:59 AM
There is no way, no how, absolutely FORGET even thinking about simply measuring off some other frame or something like that on putting that motor in there! You put the cab on, you put the motor in there and and you set it up with the rad support on so you KNOW what you are doing.
You are trying to skip a step by "cheating". Setting the engine in there and seeing exactly what you are working with is the ONLY way I would ever do this.
Please don't take this as a dig to Speed Bump who has spent the time providing you with measurements. Which of course he also suggest you put the motor in too.
I wouldn't leave it to someone else's interpretation of what to measure it off of, of knowing how to use a measuring tape, of understanding what they have said clearly, there is NO WAY, NO HOW I would weld in motor mounts or anything else like that without putting the motor in the truck!
If you have built an exact truck before and know a particular measurement that works, fine. But to take a number from someone off the net and weld in motor mounts, there is NO WAY.
You want to KNOW, you want to understand WHY you are putting that motor just where you put it. In your particular swap it had an inline six in there, so yes there is plenty of room for error. But you are still talking about close tolerances with a little bit different location. Put the motor in there and build it around what you see.
Old 03-25-2012, 09:01 AM
no guessing
EXACTLY! Put the darn thing in there, don't try to cheat!
custom WIDEned 1940 chevy truck caseyscustoms Hotrodders' Lounge 11 03-04-2012 09:33 PM
V12 Jaguar in a 1940 Chevy Pickup Truck moff1959 Introduce Yourself 23 12-24-2011 01:26 PM
1940 Chevy truck ifs probird Suspension - Brakes - Steering 4 12-08-2011 07:18 PM
1940 chevy truck frame probird Suspension - Brakes - Steering 8 11-12-2011 09:36 PM
48 Chevy 1/2 ton V8 engine placement tomy2tone01 Engine 3 12-09-2002 01:59 PM
