1940 Desoto front end replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2011, 05:29 PM
Any ideas on a front end and a rear end that will be an easy swap for my 40 Desoto. I could hunt for the parts and just rebuild the current one that is there but I want this car to be a daily driver and built for the long road runs. I also plan on using this for hauling a trailer behind it. The front tread on it measures 57 inches and the rear is just short of 61 inches. It has to stay all Mopar guys. I am just that determined to keep it all MOPAR. My email is t.north_asm@yahoo.com. Thanks for any help.
Old 12-17-2011, 11:27 PM
jalopy45's Avatar
The frame width should be close to the torsion bar set-up used in the A bodies.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 12-18-2011, 09:58 AM
Wiki Edits: 49
If you want to keep it all Mopar (and I applaud you for this), probably the best solution would be a Volare front end. This setup is pretty popular among Mopar guys and has been used in everything from street rods to pickups.
Good luck with your build.
Centerline
HotRodsAndHemis.com
"Don't retreat.... just reload." - Sarah Palin
Old 12-18-2011, 07:32 PM
desoto front end
First response with a photo. I am in the Dallas texas area and should be able to find a front end around here somewhere. There are probably over two hundred wrecking yards aaround here. Thanks
Old 01-10-2012, 01:21 PM
67Elcamino's Avatar
Im about to pick up a very clean 1940 Desoto Coupe. It has an original Flathead straight six 3 on the tree. Do you guys know what size engine type of tranny they came with etc.. Any warnings before I purchase LOL
Old 01-10-2012, 03:28 PM
Wiki Edits: 49
DeSoto is an orphan car. Not many of them out there and pretty much no one is making body parts for them. Before you buy... make sure all the major body parts are there and usable. Doesn't mean they have to be perfect just repairable. Trying to find a replacement fender for one of those could take years of searching so a complete body is the most important thing. Mechanicals, as long as you're not intending to "restore" the car are not important at this point so don't let that get you sidetracked. You'll wind up replacing the driveline anyway as well as upgrading the suspension systems and brakes. So.... just make sure the body parts are all there and are repairable and you should be OK.
Centerline
HotRodsAndHemis.com
"The only place you'll find a helping hand is at the end of your own wrist" - Joe "Dr. Olds" Mondello
Old 01-16-2012, 12:04 PM
67Elcamino's Avatar
I also will be looking into a frond end replacement. Still not sure whether I customize this car or restore it all original.. No major rust issues and all original except for the front seat 'mounts'?? looks like the front bench seat is sitting on 2x4's??
Been told I better not dare to start customizing removing and cutting stuff off.
Old 01-16-2012, 03:09 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Nice car.
Tell who's been tellin you to stop tellin you.
Do what you want with it if its yours.
Unless of coarse a family member gave it to you and may cause conflict, act accordingly.
Old 01-17-2012, 10:19 AM
67Elcamino's Avatar
Centerline
HotRodsAndHemis.com
Interested in this front end sutup Volaire? What year and model is this front end from?
front suspension 38 DeSoto 38 special Suspension - Brakes - Steering 3 06-28-2005 10:36 AM
Wheel Studs on 1940 Desoto mile-hightoyz Suspension - Brakes - Steering 3 09-12-2004 08:34 PM
1940 Desoto Sedan Parts? mile-hightoyz Suspension - Brakes - Steering 8 05-31-2004 11:32 AM
1940 DeSoto HEARTBREAKKID Hotrodders' Lounge 13 10-12-2002 04:03 AM
1940 truck front-end kyle214 Suspension - Brakes - Steering 2 05-28-2002 05:44 AM
