1940 Ford Coupe WONT START - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2012, 05:05 PM
Changed oil...Flipped stock column switch.....everything was electrified....Pushed button.......And NOTHING.........I'm challenged electronically...........I pulled button for identification.....Any Ideas?
ID:	69458   Click image for larger version
Old 11-29-2012, 05:27 PM
Wiki Edits: 27
wont start?
More explanation is needed ! Engine doesn't turn over? or turns over but wont fire ? If it won't turn over check battery cable connections, starter connections, clean with a battery terminal cleaner, othe connections with a wire brush. If it doesn;t fire check key ignition circuit. The old distributors mounted on the front of the engine have a flexible wire inside with hair sized wires. with age the insulation deteriates and shorts out .
1940 ford 5 window coupe incautious Hotrodders' Lounge 31 07-12-2011 06:56 AM
Lost 1940 Ford Business Coupe! Gary Kalipolites Introduce Yourself 4 09-19-2009 09:06 PM
FMX Transmission into a 1940 Ford coupe 4041Ford Hotrodding Basics 7 08-20-2009 10:49 AM
700R4 in a 1940 Ford Coupe waltmail Transmission - Rearend 20 07-29-2006 07:20 AM
1940 ford coupe frames Allen Lee General Rodding Tech 5 01-21-2006 02:41 PM
