1940 ford deluxe -rims and tires - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2009, 09:26 AM
the car is completely stock but i am looking for some really nice rims and tires...soemthing that will fill up the wheel wells nicely and something that will also lower it a little bit...
any suggestions ?
Old 04-23-2009, 04:18 PM
On my basically stock suspension 1940 Ford standard businessman coupe ... I just used a set of 55/56 F-100 rims on the front. They come in a 15 inch rim size and I had 165/15/80R Kumos on the front. On the rear I had a widened rim with the F-100 center and used a 225/75/15R tire.
I also had a dropped axle and a reversed eye spring in the front and a rear spring de-arched.
Old 05-12-2009, 10:11 AM
bolt pattern
any clue what size the bolt pattern is ?
thanks for your help...nice coupe!!
Old 05-12-2009, 10:39 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The pattern is 5 on 5-1/2".
That IS a nice coupe!
Old 06-02-2009, 10:17 AM
1940 ford coupe stock rims and tires ??
does anyone have a stock coupe with aftermarket rims and tires ? i am trying to finish my dads coupe for him and i cannot figure out what to do . the axles stick out on it so the moon hubcaps work but what else will work onthere...
i might be forced to runs stock rims and new tires on it with the moon hub caps and trim rings ...
thanks guys
Old 06-02-2009, 12:14 PM
A lot of rodders just use a set of mid 50's F-100 rims. I did
The original wheel pattern on a 1940 Ford is 5 on 5.5 and that is the same as Ford pickups for many years ( not current ones ). It is a big pattern and not the most popular pattern for the aftermarket mag wheel manufacturers.
Wheel adapters are available, but only make the track width wider and uses up valuable room when trying to use aftermarket rims.
Old 06-18-2009, 02:49 PM
what size tires are you running ?
thanks for the help !!
Old 03-19-2013, 11:15 PM
Last journal entry: Speedometer Connection
How wide are 40 ford rims and how bog of a tire will go no them?
Old 03-19-2013, 11:19 PM
40 Ford rims
How wide are 40 Ford rims and how big of a tire woll go on them??
Thanks
Old 03-20-2013, 01:05 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks
Stock '40 Ford car wheels were 16" diameter x 4" wide. Coker can give details on tire fitment, or check at HAMB. A lot of guys went to the Ford 15" wheels, 5-1/2" wide, used on 1/2 ton trucks beginning around '57 or so. Much better tire selection for these wheels using 15" tires.
Old 03-20-2013, 03:12 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Your two threads for the same issue have been merged here.
Semper Fi
34 Ford chassis w/MII front end - front tires rub heyjude076 General Rodding Tech 4 04-09-2009 08:46 PM
Rims & tires 1930 ford sport coupe psycho30ford General Rodding Tech 2 11-12-2006 12:42 AM
My wire rims leak when I use tubeless tires. nprfan General Rodding Tech 6 09-13-2005 12:04 PM
'39 Ford tires & wheels sandman351 Suspension - Brakes - Steering 1 01-11-2005 05:41 PM
New Tires / Rims Gundarak Body - Exterior 2 03-27-2004 08:39 PM
