Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1940 Ford Modular Engine Swap
Old 04-21-2012, 10:40 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Some things do come to mind for this project..The ranger rear end springs and all will do for the rear..for the engine measure up a 4.6 as I have seen several of those installed into the early models..With the ifs swap you will not need to clear the wishbones however if it were mine to do I would split the wishbones and use the Ford axle with a 4" drop..those work just fine and a lot of guys go for the ifs just because..just food fro thought..
Sam
