1940 ford truck with a 1936 flathead engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-25-2013, 08:51 PM
Hi jimmy jazz here just bought a 1940 ford truck all original engine locked up but have a spare 1936 flathead engine could use tips on installing points I know I have to pull distributor any tricks I need to know? Thank you
Old 12-26-2013, 06:32 AM
delawarebill's Avatar
points
for me i just use the dwell meter and what ever the gap is when i'm done.. i don't gap. when u pull the dist put in vise and rig up something to attach to drill and spin it.. then adj to dwell reading.
Old 12-27-2013, 07:04 AM
Guest
The best is to put the distr in an old Sun 504type machine, set the dwell & timing right there.
It takes a special fixture for the Sun machine, not everybody that has the Sun machine has the fixture...myself included. A buddy has one and its' the **** for doing the early distributors.
Old 12-27-2013, 09:03 AM
If you truly have a '36 engine the water pumps will be on the front of the heads. These are small 221ci engines with inherent cooling issues but are very hard to find and valuable to a restorer.
My thoughts are if you are blessed enough to have a good running 36 engine it would be wise to sell it and find a more appropriate flathead for the truck.
Flatheads forever.....
John
1940 Ford Deluxe coupe flathead jbrier87 Engine 6 08-15-2012 05:28 AM
Dan Alesi (my 1940 Ford Coupe/Flathead) alesi40ford Introduce Yourself 1 04-14-2009 06:22 AM
1936 Flathead 8cyl.cylinder Heads (ford) classic 1944 mooner Hotrodding Basics 2 10-22-2008 10:58 AM
1936 Ford flathead identification Scrap iron Engine 0 09-23-2007 02:12 PM
need remanefactored fenders for 1936 ford truck hooker2 Introduce Yourself 4 07-27-2007 02:59 PM
