1940 Oldsmobile Fron Axel - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2006, 12:27 AM
I need help, i dont know what to do for my 1940 Olds front axel. Can i buy a A-arm and suspension package and use original bracket on frame. Is their a clip form a newer car that will fit in easily. Can i use a Musstang 2 front axel?
Thanx
any info will help
or websites etc. of places where i can get this stuff for my front axel
Old 06-22-2006, 09:23 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You can check with Hemmings and they might know of something from the resto crowd for that..Otherwise I think you may be up for doing the MII swap..there are several good vendors for MII front cross members and that may be your best bet on that car as the MII solves the parts problem..
And I am moving this to suspension steering forum..
Sam
Old 07-20-2006, 01:17 PM
1940 Olds front clip
40 olds front clip from fatmanfab about $ 2600.00
www.fatmanfab.com
ID:	13505   Click image for larger version
ID:	13506   Click image for larger version
oldsmobile 330 heads on an oldsmobile 305 JohnnyBoy Engine 8 08-11-2009 10:37 AM
Oldsmobile engines. Meka Engine 22 06-27-2007 03:16 AM
'40 Ford front axel on a T-bucket Nightfire Suspension - Brakes - Steering 13 07-01-2005 10:46 PM
Oldsmobile F-85 starting problem oldsF85 Engine 1 03-29-2004 07:21 PM
1940 truck front-end kyle214 Suspension - Brakes - Steering 2 05-28-2002 05:44 AM
