#1
1940 pontiac--Adjusting door hinges
Hello:
My name is Dave and i am having a terrible time trying to adjust the door hinges on my 1940 Pontiac. Can anyone give me some ideas where I can get information on tihis? I would like to keep the original look without going to aftermarket hidden hinges. Thanks, Dave Register now (free) or login to remove ads |
#2
hinges
can you see them from the outside when the door is closed. If you can you might have to heat them and bend them, Is the hinge pin good, and the screws that hold the hinge to the door good. Bob |
#3
Post photos of the hinges and door shut saying where the problem is. Is the back too high, is the back to low, is the front upper gap tight, is the front lower gap too tight? Explain what the problem is and post the photos of the hinges and we can help you being not all of us have a working knowledge of a 40 Pontiac door.
Brian |
| Thread Tools | Search this Thread |
| Similar Threads for: "1940 pontiac--Adjusting door hinges" | ||||
| 1940 pontiac 4 door silveor streak | 1940 pontiac | Introduce Yourself | 6 | 07-25-2011 10:14 PM |
| Adjusting 1940 to 48 Ford Brakes | Morts Modified A | Suspension - Brakes - Steering | 1 | 09-05-2010 07:09 PM |
| Help req'd adjusting door hinges (binding) | Ripped | Body - Exterior | 5 | 11-09-2006 11:23 PM |
| door hinges | cjskustoms | Body - Exterior | 1 | 09-02-2006 04:22 PM |
| S-10 door hinges | oldred | Body - Exterior | 8 | 05-01-2006 06:16 AM |
