Bob, actually that isn't quite so. The 1941 is an oddball by itself. From what I have read, it had some designs of the 1939 and some of the '41 carried over to the '42.
I have since seen a "blueprint" page from a frame alignment book showing the 1941 which seems to have a different x-member closer in looks to the '39 (though I have seen photos and the 41 looks sort of like the 42), a different crossmember above the rear axle, and the rear of the frame is like 3-inches narrower than the '46-'48.
That is why I would like to see an "official" original frame diagram with dimensions from a Ford Service Manual covering the 1941-1942 models - for both years to validate what I see in the blueprint frame chart or dispel it.
Someone out there must have a copy of the manual or a Chilton's Motors Frame and Body Crash Book covering those years showing the frame diagrams?
Thanks!
Erix
Originally Posted by 35terraplane
According to my info. the 1941 to 1948 were the same except for some small changes. the reason being, in 1941 they were thinking about the war, in 1946,47, 48 they didn't need to change it. From 1941 to 1948 the only real change was the front end sheet metal, The bodies were all about the same.
Bob
