Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1941 Chevy 2-door saved from the crusher!
Old 06-23-2012, 09:27 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
You may wish to consider fabricating a frame..I would use the front crossmember from an S-10 and then use box tubing for the rest of it..the rear portion of the S-10 with the axle and spring hangers may work for you as well..the main difficulty with the S-10 chassis in the stock form is that it has a lot of curves and such which make life difficult in th mounting of the body and the wheel base may not match up..
Sam
