Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1941 Chevy 2-door saved from the crusher!
Old 06-23-2012, 11:28 PM
Blacktail Sniper Blacktail Sniper is offline
Originally Posted by OneMoreTime
You may wish to consider fabricating a frame..I would use the front crossmember from an S-10 and then use box tubing for the rest of it..the rear portion of the S-10 with the axle and spring hangers may work for you as well..the main difficulty with the S-10 chassis in the stock form is that it has a lot of curves and such which make life difficult in th mounting of the body and the wheel base may not match up..
I was thinking something close to that, but was considering a Camaro sub-frame. I have located a 74 shell w/rear end also for a decent price, any thoughts on whether it would fit?
Thanks, Dennis
