1941 Chevy transmission and rear end lubricant. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2008, 09:45 PM
CrashFarmer2's Avatar
Dried up in the Drought! :(
Last wiki edit: Pre-1980 VIN decoding
Last journal entry: 1978 Chevy pickup battery tray repair
Wiki Edits: 409
I have been reading this online shop manual that covers my 41 Chevy and as far as I can tell the transmission and rear end take a different lubricant. SAE 90 passenger car hypoid lubricant for the rear end and SAE 90 transmission or mineral oil lubricant for the rear end. here is a link to the page: 1941 Chevrolet Shop Manual for Passenger Cars and Trucks
So I should look to see if these are still available at a parts store?
Old 06-29-2008, 10:06 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
MY brother had an international scout that required some sort of mineral oil in the transfer case. In order to get it..he had to order a 5 gallon bucket of it from a local oil company.
He changed it a couple of times while he owned and gave the rest to the next owner.
No parts stores could get the stuff anymore and this was around 10 years ago.
I have no clue about your chevy, but he found what he needed that way.
If you do need that (can't switch to anything else) that might be a way to find it.
Old 06-30-2008, 06:17 AM
Wiki Edits: 31
90 wt for the transmission. 90H for the differential.. this is what my '53 Motors manual says for '40-'41 Chevy
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
S10 Rear End in a 33 Chevy TFoch Transmission - Rearend 2 02-04-2007 02:08 PM
Transmission question and rear end question demitristewart Transmission - Rearend 1 09-14-2005 07:38 AM
65 Chevy Rear End Gears mweber Engine 3 01-03-2004 04:05 PM
transmission rear end for 65 chevy truck shortwide65 Transmission - Rearend 0 05-28-2002 08:37 AM
