1941 dodge sub frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2008, 09:35 PM
I'm currently building a street rod out of a 1941 dodge business coupe. I would like to keep to install a 318 engine but would like to know what sub frame would work. I've heard a 1976 Volare front frame would fit perfectly for this application but not sure a uni-frame would be the way to go. Any other options would be appreciated.
Jim (midsota@gmail.com)
Old 07-10-2008, 11:51 PM
41 dodge
My buddy has a 1940 something Dodge coupe. I think he has a Volare clip. He runs a 318
Old 07-11-2008, 05:22 AM
poncho62's Avatar
Wiki Edits: 5
The Volarie subframe unbolts from the unibody........You might also havea look at a 90s Dakota subframe.
Ontario Rodders
Old 07-16-2008, 12:50 PM
I'm looking into a 1977 Dodge Aspen(same as Volare) with a 318 and auto transmission. The front frame might be the way to go for stubbing into the 1941 Dodge. Any suggestions would be helpful.
Jim
Old 06-26-2009, 12:31 PM
Aspen/Volarie clip
If you get the book by Tex Smith titled, "How to build Chrysler Plymouth Dodge Hot Rods it gives you a complete step by step explaination of how to install your Volarie front end.
Vic
The Following User Says Thank You to 41Dodge For This Useful Post:
Brian Ehresman (11-30-2012)
Old 06-30-2009, 11:09 PM
New Member
what is the track width of the dodge? when you establish that get out your tape measure and start checking front ends. anyone that says its easy usually is wrong!
Old 07-03-2009, 02:53 AM
Hey...
I am working on a 41 Plymouth rod. I used the existing frame in my 273ci V8 swap. You just have to fab up your own mounts. The original frames were quite strong.
Search my username...there are some pics on there of my project. The engine and trans are in now. It's a tight fit, but it will fit.
TY
Old 08-24-2009, 12:37 AM
Buy usa d job u savmaybyourown
im selling a shelby frame that had a 360.
just to let you know i scrapped my shelby dakota.
It will come with a complete front suspension and rear hotchkiss leafs.
set up for small block 318 360 5.7 or 6.1 hemi with schumacher style mounts im not sure they were factory.
Last edited by dinger; 08-24-2009 at 01:20 AM. Reason: Classified ad. Please use the Hotrodders Classifieds for classified ads.
Old 08-24-2009, 01:21 AM
dinger's Avatar
Take this up in the classifieds or p.m. This post is old! Look at the date, advertising is not allowed on the forum.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 09-06-2009, 02:38 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
'91-'96 Dakota. Disc brakes, rack & pinion steering and the "A" motor bolts right in. 60.7" front track.
Old 10-06-2012, 11:24 AM
I looked at a Aspen sub frame and the only problem with that is you have to straighten out the frame to use it by welding in some type of straight tube frame. I thought that the Nova subframe was the way to go because the width is almost identical. Just my thoughts on it...
Old 10-06-2012, 12:59 PM
THIS was a OLD thread ... 2008 and 2009 ...
Please let it DIE in peace.
MODERATOR ... Deuce
Old 10-07-2012, 10:53 AM
Thanks! I installed a chassis from a 1996 Dodge Dakota truck with motor and trans. I shortened the frame 10 inches and notched the rear frame and installed lowering spindles on the front. Sits real nice on this chassis plus have all the updated disc brakes, rack and pinion, auto trans, 5.2 litre engine with fuel injection. Still working on the project and hope to have it on the road soon.
Jim
Old 10-16-2012, 10:50 PM
Senior Curmudgeon
Wiki Edits: 326
Jim
Good work Jim.
See fellers, not all frame swaps end up behind the shed.
59 Chevy pickup frame woes! Li'l Pine Suspension - Brakes - Steering 33 07-08-2009 08:24 PM
1941 Dodge Street Rod midsota Introduce Yourself 9 12-24-2008 02:33 PM
1938 Dodge Frame Dimensions sodas38 Suspension - Brakes - Steering 2 11-19-2005 06:58 AM
57 chevy frame alignment question... please help! Sanspants Suspension - Brakes - Steering 1 07-20-2004 10:15 AM
Review of FatMan IFS Airbag install 1938 Chevy PU Grashopr Suspension - Brakes - Steering 3 08-25-2003 11:16 PM
