1941 Ford Coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2012, 04:07 PM
1941 Ford Coupe
How do I adjust the voltage on a stock 6 volt voltage regulator from 6 vollts to 9 volts to charge an 8 volt battery ?
Old 08-20-2012, 10:34 PM
Wiki Edits: 27
old book needed
I have my old college automotive elect text book, but most of those old regulators had 3 coil contacts sets inside You adjust point gap and spring tension to raise the output voltage.The voltage regular unit is the one with the fine wire in the coil. some of the older cars used a 3 brush generator and you could move the brush to change output. there is a Ford V8 club and forums that will probably have more info.. if you can identify what you have I could copy and PM you more info. My old text has 50 pages of Charging system info.
First project in 20 years, 1941 ford coupe Rick P Introduce Yourself 1 01-08-2011 11:36 AM
1941 ford coupe 12v converter? yeepman2 Electrical 4 07-06-2006 12:45 AM
restoring 1941 ford coupe foster 1941 Introduce Yourself 4 02-01-2006 02:27 AM
body parts for 1941 ford coupe foster 1941 Introduce Yourself 3 01-08-2006 09:57 PM
2002 mustang 4.6 installation in a 1941 ford coupe 41fordcoupe Engine 7 08-14-2003 04:42 PM
