1941 Ford Dash Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2008, 08:56 PM
1941 Ford Dash Swap
Anyone ever try to swap a different dash board in a 41 ford?
I'm thinking of swapping in a 56 ford dash. The car came with a 60 something Comet dash but its a total loss. Would it be easier to graft a 56 ford gauge cluster to a stock 41 dash OR just cut the 56 dash to fit?
Old 03-11-2008, 10:26 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I am going to move this over to body exterior..this is kinda a fine line but the body guys do more with sheet metal..Hope you have the windshield out as that will make this a lot easier..
I would put in the complete 56 dash as then you have all the proper mountings and such that comes with it..It will take a bit of trimming and fitting to get the new dash in but do a good job of it and it will be worth it..
Sam
Old 04-09-2008, 05:00 PM
tc33's Avatar
Stuck in the 30's
Last journal entry: Where it came from and how I got there - a short Summary
How about putting a 2001 PT Cruiser dash in a 36 Chevy???
See my journal for specifics.
Old 04-09-2008, 05:18 PM
Wiki Edits: 31
I wouldn't try to graft anything.. I think I'd find a '40 Ford dash. you can get all kinds of replacement gauges for it, and they look really nice.. of course it's the correct size to fit a '41 cause '39-'41 is basicly the same car
Old 06-03-2008, 09:07 PM
Try a 42-48 Ford Dash
I suggest looking at a 46-48 Ford dash. These are plentiful, often appearing on ebay in the $25-$50 price range, and can be nicely dressed up with the chrome trim for a classic look. Additionally, they are bolt in and not welded in. I measured my 47 Ford dash and at the bottom it measures approx 50 1/2 inches wide and at the distance across the top edges is approx 48 inches. I suspect that this dash would be a drop in for the 41 although the original plastic trim was different between the 41 and the 42-48 Fords. I believe the 1941 Ford cars have more in common with the 42-48 Fords than the earlier models. (i.e. 114 in wheelbase, glass, doors, ...)
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
1988 ford efi to carb swap specifics? kunstler Engine 8 03-24-2007 09:28 AM
1941 ford pickup tranny adapter davencastle Transmission - Rearend 2 10-23-2006 02:55 PM
Ford Festiva motor swap Lee Hulick Engine 19 07-22-2005 12:55 AM
TH-400 to Ford Toploader Swap fearsomefairmont Transmission - Rearend 4 06-25-2005 04:34 AM
