-   -   1941 ford mustang II -who's crossmember is the best? (http://www.hotrodders.com/forum/1941-ford-mustang-ii-whos-crossmember-best-218746.html)
sawzall 04-28-2012 07:38 PM
my next project will be a 47 ford with a 41 front clip
I've read that the 41's sheetmetal is somewhat narrower than the 46- 48's and that sometimes narrowed control arms and careful front wheel choices are important..
I would like the front wheels to be tucked in as tightly as possible..
currently I have all the stock mustang II parts necessary to do the job, (except for the cross member itself) and I believe I even have a set of airbags to fit in place of the springs... :-)
sadly I dont have a stock 41 front axle.. (or any stock style front end parts for that matter)
I like the chassis engineering front cross member (the bolt in feature would make it go together quickly) however I am wondering if I might be better served with a slightly narrower cross member mady by someone else..
search turned up lots of thougths.. just need some real world experience..
any options?
35terraplane 05-04-2012 02:18 PM
1941 Ford crossmember
any options?
Which frame are you using? The 41, or the 42/48 frame. the sheet metal from the 41 might not fit on the 42/48 frame, as the frame might be wider and the front won't match the cowl, or the grille area of the 41 is not wide enough.
Bob
dinger 05-05-2012 10:11 AM
Check these guys out, used their set up on mine, a friend that builds a lot of chassis's swears by them. http://streetrodengineering.com/
