1941 Ford pickup brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2011, 10:36 AM
I took off the stock front drums and shoes, cleaned everything and put them back together, but now the brakes lock up. Never had his happen before. I can back the truck without a problem, but they lockup going forward. Is it possible the lower eccentric washer is not seated on a front drum or maybe the eccentric is worn? Other thoughts are appreciated before I take things apart again.
Thanks,
Jim
Old 08-21-2011, 02:22 PM
jalopy45's Avatar
If it locks up going forward thye shoes or adjusters are not installed correctly, the long shoe goes towards the front, here's a diagram from Vanpelt , http://www.vanpeltsales.com/FH_web/F...r_1939to42.jpg
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
1941 ford pickup frame yeepman2 General Rodding Tech 0 08-11-2010 05:48 PM
72 Ford Pickup Brakes bristolkid Hotrodding Basics 3 07-25-2010 10:12 PM
1941 ford pickup tranny adapter davencastle Transmission - Rearend 2 10-23-2006 02:55 PM
1937 ford pickup Mustang II suspension brakes magnum2u Suspension - Brakes - Steering 1 06-24-2006 09:36 AM
'65-'72 Ford pickup disc brakes wp442 Suspension - Brakes - Steering 0 09-19-2004 07:55 AM
