1941 Plymouth Signal switch help!
3K views 7 replies 8 participants last post by  pasadenahotrod
Hey Gang...
I have a 41 Plymouth that I am going to be Hot rodding. For anyone who is familliar with this model and year range, where is the signal light switch? Is it that little toggle switch under the dash below the ignition? That's the only switch I can figure (and of course, it's not working...)
Any info would be great!
Thanks!
Ty
#8 ·
The usual self-canceling turn signal switch I have found in the numbers of 42-48 Plymouths I have owned, and ALL of them had them, was a factory accessory and you might find a 42-48 Ply or Dodge and get that switch and use it on your 41.
There are also neat little signal lights and switches for under the hood lamps, inside the trunk lamps, emergency brake ON lamps, and areally crazy accessory electonically opening gas cap.
