1941 Plymouth Signal switch help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2008, 01:56 AM
Hey Gang...
I have a 41 Plymouth that I am going to be Hot rodding. For anyone who is familliar with this model and year range, where is the signal light switch? Is it that little toggle switch under the dash below the ignition? That's the only switch I can figure (and of course, it's not working...)
Any info would be great!
Thanks!
Ty
Old 11-03-2008, 04:09 AM
They did not come with turn signals as standard equipment. In that era, hand signals were the norm. (Can you imagine the chaos if that were still the case? )
Old 11-03-2008, 04:28 AM
It must of been difficult going around a corner, shifting gears, signaling a left turn. and talking on the cell phone all at the same time. I understand those early cell phones were huge!
Old 11-06-2008, 12:11 PM
DanTwoLakes's Avatar
Wiki Edits: 22
The switch under the dash was probably for something like fog lights which disappeared over the years.
Old 11-06-2008, 10:57 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
http://www.jcwhitney.com/autoparts/P...tt=turn+signal
Check this out as this is what we used on those older cars back in the day..
Sam
Old 11-07-2008, 06:31 PM
1947 Chevy Coupe
No turn signals. FWIW, most hot rodders add them and seat belts too.
Old 12-21-2008, 04:07 PM
signal lite switch
The switch under the dash by the steering colum is the dimmer for the dash lights. On...Dim...Off. It has a resistor built into it to achieve the dimmer
Old 12-28-2008, 01:30 AM
The usual self-canceling turn signal switch I have found in the numbers of 42-48 Plymouths I have owned, and ALL of them had them, was a factory accessory and you might find a 42-48 Ply or Dodge and get that switch and use it on your 41.
There are also neat little signal lights and switches for under the hood lamps, inside the trunk lamps, emergency brake ON lamps, and areally crazy accessory electonically opening gas cap.
Turn signal switch problem maybe??? Irelands child Electrical 3 10-02-2008 01:23 PM
Turn signal switch KENMO Electrical 5 08-26-2008 04:01 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
wiring a signal switch ahaley55 Electrical 4 08-21-2005 09:41 AM
need turn signal switch & advice --help! : ) WayOutCat Electrical 8 05-01-2003 10:56 PM
