Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1942 willys sputtering?
Old 10-05-2012, 07:50 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Tee off at the carburetor inlet and run a 1/8" copper tubing line up to the cowl. Install a mechanical 0-15 psi fuel pressure gauge on the cowl so you can see it and monitor the fuel pressure through the windshield. I think you'll either find too little or too much pressure. This is just a wild guess based on experience, but I would think you'd want around 3 psi. A factory service manual will tell you for sure. You can get one from Faxon....
Faxon | Shop Manuals for Car & Truck Owners | DIY Service, Repair or Maintenance
