1942 willys sputtering? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2012, 06:15 PM
i have a 1942 willys jeep that has a f head motor. i put in new points, new coil, new every thing but the engine. when i drive it down the highway it does good till you hit third gear it starts to sputter bad. any suggestions?
Old 10-05-2012, 06:50 PM
techinspector1's Avatar
Wiki Edits: 326
Tee off at the carburetor inlet and run a 1/8" copper tubing line up to the cowl. Install a mechanical 0-15 psi fuel pressure gauge on the cowl so you can see it and monitor the fuel pressure through the windshield. I think you'll either find too little or too much pressure. This is just a wild guess based on experience, but I would think you'd want around 3 psi. A factory service manual will tell you for sure. You can get one from Faxon....
Faxon | Shop Manuals for Car & Truck Owners | DIY Service, Repair or Maintenance
1942 Willey's street rod toolman1962 Introduce Yourself 3 07-18-2011 05:25 PM
1942 chevy driveline big block chevy Transmission - Rearend 3 05-03-2009 04:19 PM
Turn-Key 41 Willys Coupes & 41 Willys Roadsters Tmcswiney Introduce Yourself 1 01-27-2009 09:08 PM
1942 ford gpw lvhandy1 Introduce Yourself 1 02-14-2007 08:48 PM
1942 Pontiac trustedsole Introduce Yourself 1 11-04-2004 05:12 AM
