1946 chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2004, 02:09 PM
1946 chevy truck
I have a 1946 chevy 1/2 ton pickup, and i'm tired of all the problems that goes with it. just wondering what is the best newer model frame i can put my body on. some people say a chevy -s10 extended cab, others say camaro. anyone out there know. thanks
Old 01-29-2004, 02:42 PM
USA1's Avatar
Just sell it to me real cheap and I'll let you know. I have heard of people using 67 to 72 chevy truck frames on these trucks. Only problem is how scarce short bed trucks are around here. Good luck, and if you do want to part with it, PM me.
Old 01-29-2004, 06:08 PM
Wiki Edits: 49
The S-10 would be a better choice since it's a bit narrower. The Camaro clip is too wide even for the AD trucks which are a bit larger than your '46.
Do a search of the knowledge base. There have been a lot of conversations on this subject that you could benefit from.
Centerline
Old 01-30-2004, 04:31 AM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
What kind of problem
What kind of problems are you having?? I'm building a '46 Chevy 1/2 ton Panel truck. Let me know I might have had the same ones and can help you figure it out. Also sent you a PM with some other info in it.
David
