1946 ford pickup suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2003, 10:14 PM
biglee550's Avatar
New Member
Question 1946 ford pickup suspension
Hello all. I'm new to the site.
I just bought a 1946 ford pickup and going to put a subframe on it. What is the best subframe to use that will line up close? Don't really want a mustang clip!
Please state a good year of frame to use.
Also, i'm a good backyard mechanic but this is my first restoration project so bare with me.
Gonna have a lot of questions in the future. Thanks, Lee
Old 07-29-2003, 07:55 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
dont cut the frame, if you're dead set on changing the front suspension then what I would do is find a late model Ranger p/u & use the complete frame under your truck. I have seen a few of these swaps done & have talked to the folks who own them & what I have been told is it's pretty much a simple bolt on. You will have to move or make new body mounts but IF you use a late model frame you get all the modern suspension & brake upgrades. Also the trucks I have seen were running 5.0's & V6's, so you could run just about any power plant you like...joe
Old 07-29-2003, 09:09 AM
IMO the correct way to go would be to get with No Limit Engineering and talk with Rob about installing one of his front crossmember....... Doing that you can also get updated brakes and steering. I dont recommend doing a ranger frame....... the ranger front suspension is junk when it comes to modifying them and there are very few quality aftermarket components available for them. If you were going to try to chassis the whole thing using an OEM chasis, I would try to squeeze an S-10 under it. But still the easiest route to go is with an aftermarket cross member.
Tony....
Old 07-29-2003, 03:48 PM
biglee550's Avatar
New Member
Thanks for the reply's.
What do you think of using a camaro,firebird,or nova subframe and what year ? I see alot of people use them on there old pickups!
PS. I am also a certified welder. I wont have any problems welding the subframe to the existing frame. Thanx Lee
Old 07-29-2003, 09:51 PM
Wiki Edits: 5
http://www.chevytrucks.org/tech/ifs&rearend.htm
http://www.streetrodstuff.com/Roundt...ctober/177.php <~~ scan down the post
check these sites & they'll tell you how wide the different suspension are, so you can see what you can use.........joe
Old 07-30-2003, 07:01 AM
biglee550's Avatar
New Member
Hey Joe.
This is what I have been looking for. You have been very helpful, and i do thank you for the info. I'll keep ya posted on what i decide.
Thanks,Lee
PS. Do you have a good site or a catalog that i can get repair panels for my fenders on my 46 ford p/u ?
Thanks Again,Lee
Old 07-30-2003, 07:48 AM
Wiki Edits: 5
http://my.execpc.com/~sonoma/
http://www.ford-trucks.com/forums/archive/forum/42.html <~~you can post a QQ here also
http://www.RestoreTrucks.com
http://www.parts123.com/inven_antique_and_classic.htm
http://www.mercurypickup.com/ its mercury but it may help
these are a few I have found, but also look for a Ford forum & they maybe able to help you more........joe
Old 07-30-2003, 01:52 PM
biglee550's Avatar
New Member
Hey Joe,
Thanks for the new sites. Visited all of them and this should keep me busy for a while. Can't tell you how much I appreciate the help.
Thank You,Lee
Old 07-31-2003, 06:32 AM
biglee550's Avatar
New Member
What rear end to use?
Hey All,
If any of you have anymore helpful hints on restoring this 46 ford p/u, please reply back to me with your coments. This is a great site to have and it has benefited me already. Hope to use it more in the near future.
Any idea's on what rearend to use? Planning to use this p/u for everyday running around and showing it off. Not planning to put it in any car shows but mite pop in a couple here and there. Not planning any heavy loadsd on this old beast. I prefer to use leaf springs on rear and not coils.
PS. Please e-mail me with any coments or helpful hints if you prefer.
Thanks, Lee
Old 07-31-2003, 08:05 AM
Wiki Edits: 5
check this site http://www.chevytrucks.org/tech/ifs&rearend.htm it'll tell you how wide the rearends are. What i would use is just about anything that will fit since its going to be a daily driver. I have used ford 9"- 8"- chevy 10 & 12 bolt or even a chry 8 3/4, but really anything will work fine AS LONG as its wide enuff for your truck.........joe
Old 07-31-2003, 07:57 PM
biglee550's Avatar
New Member
Hey Joe,
Thanks again for the help. I'll keep ya posted on my findings.
Thanks, Lee
Old 08-05-2003, 06:54 AM
Pontiac Knowledge Base Editor
My 61 F100 is getting the Aerostar treatment. I'm in the process of making the upper control arm brackets right now. The only thing I dont like about this swap is that it will only lower the truck 6" which means I have 6 more to go. My bumper is 16" off the ground now and I would kile it to be down to 4" from the ground. Will have to see how it sits with the weight back on it.
