1946 Ford Truck Chasis Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2008, 09:19 PM
I just recently bought a 46 Ford Truck and want to use a modern driveline. It appears that the Ranger is an ideal candidate due to the almost perfect wheelbase match. Is this a fairly straightforward swap, or should I consider welding on some sort of subframe and keeping the current frame, rearend, etc. Any info you could provide would be appreciated.
Chris Lane
Mustang, OK
Old 03-16-2008, 09:52 PM
life is a temporary assignment
No matter which way you go,You will need to do some welding.I like to put front clip's under them.I did several last year.I have a 57 Chevy frame in my album,That I put a camaro clip on.I also did a 58 Chevy truck that I put a Nova clip on.also in my album. The Nova is 1.5'' narrower then the camaro.(Hub to hub)
Old 03-17-2008, 01:51 PM
With the ranger swap you will need to weld up some body mounts for the cab, bed and front fenders. I've done front clips and the ranger swap and I prefer the ranger swap on trucks. I've done it on a 48 ford and it really wasn't as bad as people make it out to be. Be prepared for alot of work but front clip swaps aren't exactly laborless either. Front clips are faster to fab up but there is a huge benefit to having a whole frame swap. If you decide to get a ranger frame try and get the brake booster & steering column. Also save yourself a step look for a 4.0L ranger. Tey usually have 8.8 rear ends & the bigger 10" brakes.
Old 12-28-2008, 10:00 PM
alesi40ford
trans for 1946
Hi,
Dan Alesi
xxxxxxxxxxx
No advertising allowed ... and the guy has NEVER been back
Last edited by Deuce; 12-29-2008 at 04:56 AM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 01-18-2010, 03:52 PM
alesi40ford
no problem
My bad,
I was looking for help.
thx for the input, I have reviewed the guidelines and understand.
kind regards.
Dan
looking to decode a vin # ford truck since 73 Dubz Hotrodding Basics 6 02-12-2009 01:28 AM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
I loved the girl and her dad's Ford truck T.C. Introduce Yourself 5 07-30-2006 05:49 PM
ford truck question william r plise Body - Exterior 3 05-11-2006 05:38 PM
66 ford truck swapping a 240 i6 out for small block chevy igotachevyor2 Engine 0 04-14-2002 03:19 PM
