1947 - 1954 AD Truck / Suburban V8 conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2005, 10:36 PM
Sly's 53 Suburban's Avatar
Last journal entry: Completed the side window installation
I've searched throughout the board and was unable to find an answer, so here's a new post. I've built a Chevy 350 with block hugger headers and 700R4 to install in my 1953 Chevy Suburban. Going with a 4" drop straight axle from CCP. I'm trying to purchase all of my parts before installing the engine and transmission. I've heard many opinions about installing a V8 in an old AD Truck and most opinions are pure hear say. Has anyone here done a V8 conversion in a 1947 - 1954 Chevy AD Truck? Is the cleanest install going with a front of the cross member power steering setup? Is there an equally clean other option? I'm hoping to benefit from the experience of you here at Hotrodders, rather than trial and error. All your input is appreciated.
Old 02-07-2005, 10:47 PM
BOBCRMAN@aol.com's Avatar
I have done several. The biggest problem is the stock steering box. Eliminate that and the install is very easy. Just place the engine forward enuf to clear the dist/firewall and the rest is basic install.
I have not done one with the straight axle retained and a different box.
Old 02-07-2005, 10:48 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Since you are going back with stock suspension and I-beam axle, consider using the Toyota Land Cruiser gear like I did on my '53. Almost identical in size and shape to the original '53 Chevy gear and mounts in pretty easily.
Old 02-07-2005, 11:42 PM
Thanks for the quick replies. You say the Toyota box is almost identical to the original. I would be happy with manual steering. Could I just cut the original shaft and have it key'd to accept a new column. Is the Toyota box moved forward in your picture? The picture is a little confusing? Hard to see where the header runs and then I see some brass fittings.
As I read back through my post I wanted to clear up my question. I'm not concerned with getting power steering. I would prefer to stay manual if it's not to much work. My concern is with the possibility of the gearbox interfering with my headers. Sorry, if I wasn't clear enough.
Old 02-08-2005, 08:52 AM
Wiki Edits: 49
Sorry. Unless you're putting a hemi in there I can't be of much help.
Actually the advice you've been given so far is right on the money.
Centerline
Old 02-08-2005, 09:02 AM
Wiki Edits: 21
That Toyota box is in stock location. My engine is a 235 inline 6 so that is the reason for the confusing plumbing. I guess you could modify the stock gear for a separate column. Just remove the column, cut off the shaft and have it machined for a double "D" adapter end. Another option is find a 60s-70s Econoline box which is a popular donor.
Old 02-08-2005, 07:39 PM
Centerline,
What was done in order for your engine to fit? Is the column in the original position? What combination of gearbox and column did you use? Is there enough clearance to do as willys36@aol.com
mentions, cut the original shaft and double D to accept an updated column?
Old 02-08-2005, 08:30 PM
Wiki Edits: 49
Centerline,
Based on the pics Willys36 posted I don't believe there would be enough room. I'm using a Mustang II IFS with power rack hooked to a double "D" shaft which is then connected to a mid 80's Chevelle (I think) column. With that setup I have about 3/4" clearance around the stock exhaust manifold. I would have had a bit more clearance if I had set the engine a little higher in the frame. As it is it's set pretty low.
Many people don't realize this but you can put a Chrysler early hemi almost anyplace you can put a SBC with headers. They wind up being almost exactly the same width because of the extra clearance required for the headers on the SBC.
The trans is a TH-350 with a custom crossmember.
Centerline
