1947 chevy car rear axle
Hi I have a 1947 Chevy Stylemaster. I am putting in a SBC and Automatic transmission. I would like to know if the rear axle in the car will work or if there is some sort of conversion for it, or do I need to get a new axle and driveshaft.
Thanks for your help Vern
that 47 should be a torque tube rear axle setup.
Requires different trans , drive line , rear differential ... the diff would need special locating mount to center the axle in the wheel well opening or replacement leaf springs with centered spring pin
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Thanks for the info
I was hoping I did not have to do an entire swap. But I had a feeling I would. Does anyone know any companies that make swap kits? Also what would be the best rear axle assembly to try to find.
Thanks for any help |
companies make the correct type leaf springs, easy swap is gen II camero
| 61 chevy 1/2 ton rear axle | goneinsixty | Transmission - Rearend | 1 | 02-18-2009 08:57 PM |
| 1954 Chevy car rear end swap help! | gunner_xm192 | Transmission - Rearend | 1 | 10-18-2004 02:17 AM |
| 1947 Chevy Aerosedan 4-Link Rear Suspension Kit??? | djjc76 | Suspension - Brakes - Steering | 3 | 09-10-2004 03:06 PM |
| Door Alignment | Ron M | Body - Exterior | 2 | 08-21-2004 01:43 AM |
| Removing fenders? | Jag Daddy | Body - Exterior | 3 | 11-26-2003 04:42 AM |
