1947 chevy fleetmaster frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2009, 03:14 PM
since my last thread i have gotten another frame cheap (free) that went to another 47. my question is that it is completely closed in (boxed ???) attached by rivets. should i drill or grind the rivets so i can get to the inside of the frame rails to be sand blasted. to save on the expense i am considering just getting out the grinder and wire wheel. or should i just leave it together. the frame only has surface rust and appears to be very solid. thanks in advance
Old 02-01-2009, 05:52 PM
47chevy's Avatar
Last journal entry: Here is the car after paint
The 2 Chevys of that era that I have worked on were welded together. The hat (top) and flat bottom have been spot welded in several spots along the entire frame. I think if a person would grind or drill all of the welds out it would ruin the frame. I just cleaned both of the frames and painted it with JD Blitz black.
Old 02-08-2009, 10:16 AM
machinist & fabricator
some parts are welded, some are rivited.
got oxy/acc?
if not, get a grinder with a cut off wheel, peel the head off and use a air hammer with a punch bit to force out the rest.
those frames can be boxed. but make sure its square and plumb.
Old 02-08-2009, 10:55 AM
If it were me I would have it dipped, thats what I would do then take a pickhammer to see how thin or thick the metal is then go from there
Old 02-08-2009, 01:01 PM
47chevy's Avatar
They were boxed from the factory. They are a top hat design.
Here is the frame from my car, yours should be the same. These pictures are not the best but it should give you an idea how they are made. The original front suspension is bolted in, the transmission crossmember is rivieted. I had a MII crossmember welded in.
[IMG][/IMG]
[IMG][/IMG]
frame swap for 1950 chevy truck truck1950 Hotrodding Basics 39 06-24-2015 03:40 PM
Subing Nova frame into a 1957 chevy truck frame crshields90 Suspension - Brakes - Steering 1 02-02-2008 10:15 PM
frame swap for 1950 chevy p/u chevykid33 Introduce Yourself 2 08-13-2007 11:05 PM
1947 Chevy Fleetmaster Sport Coupe djmsearay Introduce Yourself 2 03-09-2006 05:47 PM
Chevy S-10 frame strength/to a 350 cu.in. 55 chevy rebuild Engine 1 02-11-2006 09:56 PM
