-   Projects/Builds/My Ride (http://www.hotrodders.com/forum/projects-builds-my-ride/)
-   -   1947 Dodge Deluxe D24 Series, Project (http://www.hotrodders.com/forum/1947-dodge-deluxe-d24-series-project-234185.html)
Ol' Dodge 06-21-2013 12:41 PM
5 Attachment(s)
Here is the ins and outs of my 47 Dodge. A little bit of background on it first. I got this car from a friend. I didnt pay anything for it. I fell in love with it when i saw it even though I knew it was a lot of work. I am new to building. I want to get my hands dirty and work in building this but I know I will need help with it as I am not very experienced.
The engine that is in it I was told is a 350. When it got dropped in the owner that dropped the engine in cut out the firewall. I am attaching all the ins and outs of my dodge. all the stuff that came inside too lol. enjoy the pictures. and i look forward to comments and feedback on it. i would also like tech advice on the engine situation but ill have post in the tech section for that.
Ol' Dodge 06-21-2013 12:42 PM
5 Attachment(s)
here is more of the car. I think one more reply to this will show more of the car
Ol' Dodge 06-21-2013 12:44 PM
5 Attachment(s)
Here is the engine and the cut out firewall
Ol' Dodge 06-21-2013 12:46 PM
5 Attachment(s)
ok this is the last one. Sorry There was a lot of angles to how the condition of this car.
RS1979 06-21-2013 02:06 PM
From the pictures, it looks like you've got close to a foot of room in front to move the engine forward. You need to find an experienced welder to do that job. The transmission will have to be moved also as will the transmission crossmember. Make a list of what needs to be done and start working your way to the bottom. Good luck Dodgeman. Keep us posted.
Ol' Dodge 06-21-2013 02:14 PM
There is a lot of room to move the engine forward. The one mechanic I had look at it said that if the engine is going to be moved forward that the steering column would be in the way. I think you are right on making a list of what needs to be done and work my way down. Only problem is Im not sure what all needs to be done besides the obvious.
RS1979 06-21-2013 03:06 PM
I lived in L.A. for a few years and saw many old hot rods built from cars like yours. Check your area for some custom shops and see if they can help.
Ol' Dodge 06-21-2013 03:14 PM
Thats a good idea!! Thanks man!
charleydodge 06-22-2013 12:09 AM
nice choice ! i have a 47 with a 350. firewall is still complete and the steering box is original, and in the stock location. inner fenders will have to be trimmed. another problem is headers. i haven't found a set to work yet.
RS1979 06-22-2013 07:32 AM
Have you tried block hugger headers? They're designed to fit in tight spaces. Hooker makes a good set. You'll lose some low end torque; but, they're still better than stock manifolds.
timothale 06-22-2013 08:09 AM
engine off-set
A lot of cars-vans were made with the engine off-set to the side, You might be able to move it over a bit to have clearance. Ideal is centered, mabe trim a bit off the front coil spring to get it to set level.
charleydodge 06-22-2013 10:11 AM
sure, i think the huggers might work, but i need them to go into the wheel wells to hook up to the side pipes. the steering box mounts to the inside of the frame rails, really close to the head . not a lot of room. old style 4 into 1 out the back might work, but i haven't found them yet .
BOBCRMAN@aol.com 06-22-2013 11:00 AM
I also have a 47 Dodge. Mine is a busines coupe. The one with no side window and a looong trunk.. SBC with 400 turbo. No firewall cutting and uses block hugger headers. Cavalier rack&pinion steering and a few www.Fatmanfabrications.com front end parts.
charleydodge 06-22-2013 10:28 PM
does the steering box mount in the same location ?
NEW INTERIORS 06-22-2013 10:38 PM
That's not a SBC 350 you have..
