1947 Dodge Deluxe D24 Series, Project - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
Old 06-21-2013, 11:41 AM
Ol' Dodge's Avatar
Here is the ins and outs of my 47 Dodge. A little bit of background on it first. I got this car from a friend. I didnt pay anything for it. I fell in love with it when i saw it even though I knew it was a lot of work. I am new to building. I want to get my hands dirty and work in building this but I know I will need help with it as I am not very experienced.
The engine that is in it I was told is a 350. When it got dropped in the owner that dropped the engine in cut out the firewall. I am attaching all the ins and outs of my dodge. all the stuff that came inside too lol. enjoy the pictures. and i look forward to comments and feedback on it. i would also like tech advice on the engine situation but ill have post in the tech section for that.
ID:	75053   Click image for larger version
ID:	75054   Click image for larger version
ID:	75055   Click image for larger version
Name:	2012-06-12 16.33.31.jpg
ID:	75056   Click image for larger version
Name:	2012-06-12 16.33.40.jpg
Old 06-21-2013, 11:42 AM
Ol' Dodge's Avatar
here is more of the car. I think one more reply to this will show more of the car
Name:	2012-06-12 16.33.10.jpg
ID:	75058   Click image for larger version
Name:	2012-06-12 16.33.19.jpg
ID:	75059   Click image for larger version
Name:	2012-06-12 16.24.00.jpg
ID:	75060   Click image for larger version
Name:	2012-06-12 16.24.13.jpg
ID:	75061   Click image for larger version
Name:	2012-06-12 16.33.49.jpg
Old 06-21-2013, 11:44 AM
Ol' Dodge's Avatar
Here is the engine and the cut out firewall
Name:	2012-06-12 16.24.23.jpg
ID:	75066   Click image for larger version
Name:	2012-06-12 16.42.42.jpg
ID:	75067   Click image for larger version
Name:	2012-06-12 16.42.48.jpg
ID:	75068   Click image for larger version
Name:	2012-06-12 16.43.00.jpg
ID:	75069   Click image for larger version
Old 06-21-2013, 11:46 AM
Ol' Dodge's Avatar
ok this is the last one. Sorry There was a lot of angles to how the condition of this car.
Name:	2012-06-12 16.34.01.jpg
ID:	75071   Click image for larger version
Name:	2012-06-12 16.34.09.jpg
ID:	75072   Click image for larger version
ID:	75073   Click image for larger version
ID:	75074   Click image for larger version
Old 06-21-2013, 01:06 PM
Last journal entry: MY WIFE'S NEW REFIGERATOR
From the pictures, it looks like you've got close to a foot of room in front to move the engine forward. You need to find an experienced welder to do that job. The transmission will have to be moved also as will the transmission crossmember. Make a list of what needs to be done and start working your way to the bottom. Good luck Dodgeman. Keep us posted.
Old 06-21-2013, 01:14 PM
Ol' Dodge's Avatar
There is a lot of room to move the engine forward. The one mechanic I had look at it said that if the engine is going to be moved forward that the steering column would be in the way. I think you are right on making a list of what needs to be done and work my way down. Only problem is Im not sure what all needs to be done besides the obvious.
Old 06-21-2013, 02:06 PM
I lived in L.A. for a few years and saw many old hot rods built from cars like yours. Check your area for some custom shops and see if they can help.
Old 06-21-2013, 02:14 PM
Ol' Dodge's Avatar
Thats a good idea!! Thanks man!
Old 06-21-2013, 11:09 PM
nice choice ! i have a 47 with a 350. firewall is still complete and the steering box is original, and in the stock location. inner fenders will have to be trimmed. another problem is headers. i haven't found a set to work yet.
Old 06-22-2013, 06:32 AM
Have you tried block hugger headers? They're designed to fit in tight spaces. Hooker makes a good set. You'll lose some low end torque; but, they're still better than stock manifolds.
Old 06-22-2013, 07:09 AM
Wiki Edits: 27
engine off-set
A lot of cars-vans were made with the engine off-set to the side, You might be able to move it over a bit to have clearance. Ideal is centered, mabe trim a bit off the front coil spring to get it to set level.
Old 06-22-2013, 09:11 AM
sure, i think the huggers might work, but i need them to go into the wheel wells to hook up to the side pipes. the steering box mounts to the inside of the frame rails, really close to the head . not a lot of room. old style 4 into 1 out the back might work, but i haven't found them yet .
Old 06-22-2013, 10:00 AM
BOBCRMAN@aol.com's Avatar
I also have a 47 Dodge. Mine is a busines coupe. The one with no side window and a looong trunk.. SBC with 400 turbo. No firewall cutting and uses block hugger headers. Cavalier rack&pinion steering and a few www.Fatmanfabrications.com front end parts.
Old 06-22-2013, 09:28 PM
does the steering box mount in the same location ?
Old 06-22-2013, 09:38 PM
life is a temporary assignment
That's not a SBC 350 you have..
The Following User Says Thank You to NEW INTERIORS For This Useful Post:
5.2jeepyj (11-26-2013)
1947 dodge 3 window coupe 1934woodies Hotrodding Basics 1 10-12-2011 07:45 PM
1939 - 1947 dodge parts? poy41 Body - Exterior 9 08-25-2011 05:18 AM
1947 Studebaker M-5 Project STRODDER Hotrodders' Lounge 5 06-05-2007 10:05 PM
Need Rocker 1947 Dodge Coupe 47Dodgecoupe Body - Exterior 1 10-08-2006 07:54 PM
1947 Dodge Coupe Danny Doc Introduce Yourself 1 12-24-2004 06:47 PM
