1947 Ford in Dans profile - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2010, 10:50 PM
ronbo's Avatar
Could you share some details? Are the door panels different depth foams? Could I sew two materials together at the seams for some elevation change? On the ceiling, 1/2 sew foam or landau foam. Is the foam then contacted to the roof? How are the bows(?) fastened? I have a '32 Ford with built in headliner, a like a Harwood or Bear(?) Hoping I can sew the pattern into the headliner either on landau or sew foam and glue to the fiberglass headliner.
Thanks in advance for your suggestions.
Old 11-17-2010, 08:25 AM
DanTwoLakes's Avatar
Wiki Edits: 22
The door panels have 1/2" foam in three different places and the strip in the middle 1/8" padding. The lower portion has since been replaced with carpet. There is no landau foam anywhere in the car. At each one of the divisions, there is a seam that was either glued down or mechanically fastened with staples. The headliner is done the same way, the center is 1/8" thick and the rest is 1/2" thick. The headliner is upholstered to a piece of waterproof panel board, which is screwed and glued to a piece of 1/4" luan plywood which is screwed to a grid built out of 3/4" hardwood plywood, and attached to the car on the sides and front and back. If I was doing this car today, the headliner would be upholstered to a piece of PVC foamboard. Yes, you can do whatever you want on the fiberglass headliner with either landau foam or sew foam. You'll need to sew on a perimeter of fabric that will be attached to the car.
Old 11-17-2010, 12:17 PM
ronbo's Avatar
Thanks for the info. Why no landau foam? I'll have to find some 1/4 " sew foam. thanks again.
Last edited by DanTwoLakes; 11-17-2010 at 03:11 PM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 11-17-2010, 03:09 PM
Wiki Edits: 22
There is nothing that says you need to use closed cell foam, or anything else for that matter, to pad anything. It's usually a case of personal preference.
There are some places that closed cell foam works better, and then I do use it. These door panels were done with closed cell foam.
ID:	50072   Click image for larger version
50 Ford F1 w Monte Carlo Clip joe123 Suspension - Brakes - Steering 5 05-26-2008 06:48 AM
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 01:37 PM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 05:18 PM
1947 Ford truck ring and pinion set -NEED Pontiacman Transmission - Rearend 2 11-13-2003 06:02 PM
1947 Ford gears Pontiacman Transmission - Rearend 0 11-10-2003 09:20 PM
