1947 Ford Truck Homemade Box - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2010, 03:35 PM
car enthusiast
Last journal entry: Future Build: 1927 Dodge 5 window coupe
Here is some of the progress i made so far on my homemade box for my 47 ford. I am using 2x2x1/4" tube across the frame, 1 1/2 x 1/8" angle iron, and 18 gauge sheet metal.
ID:	48524   Click image for larger version
ID:	48525   Click image for larger version
ID:	48526   Click image for larger version
Old 09-29-2010, 04:56 PM
cboy's Avatar
Last journal entry: Finished
Looking good so far.
Always learning...and sharing what I've learned.
Old 09-29-2010, 05:21 PM
car enthusiast
thanks cboy.........
Old 09-30-2010, 03:06 PM
car enthusiast
Here are some pictures from today's work. Ran out of welding wire, and debating on running into town. Anyways, i used some 1 1/2" 12gauge tubing for my bed rails.....
ID:	48543   Click image for larger version
ID:	48544   Click image for larger version
ID:	48545   Click image for larger version
ID:	48546   Click image for larger version
Old 09-30-2010, 03:24 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
That is really looking good.
Cole
Old 09-30-2010, 03:30 PM
car enthusiast
Thanks cole. I really appreciate the kudos. First time i have ever done this type of build.
Old 09-30-2010, 06:36 PM
Awesome! Post a pic of the front suspension, really like the stance and I would like to see how you're doing it.
Old 10-01-2010, 05:54 PM
car enthusiast
thanks for the comments chris, i really appreciate it....The front end of the truck is done basically like a Model T with a speedway suicide front end. It has a tube axle instead of the beam. Here is a picture of the front end:
Old 10-09-2010, 02:06 PM
car enthusiast
Today i was able to build my tailgate and put a piece of metal across the outside bottom of the bed. For my tailgate, i used 1X2x11gauge tubing, a sheet of 14gauge diamond plate and some 1/2" inside O.D. pipe and 1/2" rod for hinges. Here is what it looks like as of today:
ID:	48760   Click image for larger version
ID:	48761   Click image for larger version
ID:	48762   Click image for larger version
ID:	48763   Click image for larger version
Old 10-09-2010, 05:12 PM
I LIKE IT!
Old 10-09-2010, 06:02 PM
car enthusiast
thanks chris........
Old 10-11-2010, 03:02 PM
car enthusiast
Well i decided i wanted a pop rivet look on the box, kind of make it stand out on it's own. I went and bought 1/4" x 1" carriage bolts and nuts. Using a 17/64th drill bit, drilled holes and squared them off a bit for the bolt and then attached them. I plan on tack welding the nuts to the inside of the box frame so they wont come loose.......Here are some pics of what i have done so far today, and I am not even near complete yet, just sharing the look:
ID:	48806   Click image for larger version
Old 10-12-2010, 04:45 PM
car enthusiast
pop rivet look
here is today's progress on the pop rivet look:
ID:	48835   Click image for larger version
Old 10-13-2010, 04:41 AM
Onefunponcho's Avatar
well done
The whole project looks great.
good choice on the front axle, spring, and perch
really gives it a good stance
Old 10-13-2010, 07:51 AM
car enthusiast
Thanks onefunponcho........i really appreciate the kudos.
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
90 ford truck steering box seal fast68 Suspension - Brakes - Steering 0 03-14-2010 01:24 AM
How would this style box look on full size truck? Crazy Fast on Ice Body - Exterior 3 10-22-2008 07:12 PM
Idiot Proofing My Trailer Wires Rob Keller Electrical 41 05-14-2007 07:32 AM
Stolen 36 Ford truck near Caldwell Idaho Chopt 48 Hotrodders' Lounge 4 01-07-2007 06:57 PM
