1947 thru 1954 Chevy 3100 3" drop axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2006, 09:05 PM
Sly's 53 Suburban's Avatar
Last journal entry: Completed the side window installation
Has anyone used a CPP 1947 thru 1954 Chevy 3100 3" drop axle? I'm going to use one and planned on using my original tie rod with the ball & socket style ends. The drop axle supplier said they won't work. He said I need the new tie rod and tie rod ends. If you have used the drop axle and any combination of tie rod ends, please post with opinions. Thanks
55 chevy drop spindles 55bullcan Suspension - Brakes - Steering 2 05-14-2006 07:24 AM
Chevy straight axle maxi-truck Suspension - Brakes - Steering 2 04-09-2006 05:59 PM
1954 Chevy ls1 yahyah Engine 2 05-11-2003 07:33 PM
1950 Chevy 3100 snakeoil Transmission - Rearend 7 11-11-2002 03:37 PM
big block chevy fit in 1954 truck pkaszuba Engine 3 01-03-2002 07:08 AM
