1948 Chevy front sheet metal fastener kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2009, 04:43 PM
Does anybody have any idea if such a kit is available for these cars? I saved all my old parts but I do not want to reuse 60+ year old fasteners. My brother bought a kit for his 55 chev and it was cheap and made it so easy to put everything back together. It was all lableled and came with fender gaskets.
Old 12-18-2009, 11:36 AM
amx180mph's Avatar
Cunningham and Hersh Hot Rods
Bolts
If you go to LMCtruck.com you will find bolt kits for grille, bumper, hood hinge, and body for your truck.
Dale
Cunningham & Hersh Hot Rods
Old 12-18-2009, 12:40 PM
prostreet6t9's Avatar
Differential/Driveline
You might give these guy's a try also.
http://www.fillingstation.com/
I've had great luck with them.
Old 12-18-2009, 02:27 PM
Ok thanks I will check these out but its for a 2 door sedan, the truck parts seem easier to find.
Old 12-18-2009, 03:30 PM
My bad! Sorry about that! For some reason I assumed it was a truck.
Old 12-18-2009, 03:56 PM
http://www.yesterdayschevyparts.com/
http://www.chevsofthe40s.com/
http://www.idaschevs.com/
http://www.classiccarautoparts.com/chev.html
I'm sure you may have already found these links.
Old 12-18-2009, 04:07 PM
deadbodyman's Avatar
Wiki Edits: 11
still ...the fasteners are the same if you can just match them up to the new one you'll be ok theres a lot of fastener companies. (J clips)? If times not an issue you could always spend a sunny afternoon at the bone yard collecting clips and bolts ...they might not even charge you...but if you want all the bolts labled ,I dont think you can get assembly kits for that car...
Old 12-19-2009, 01:02 AM
Will I ever get it done?
Last journal entry: More Door
http://www.chevsofthe40s.com/detail/...NAL_STYLE.html
If you call Chevs of the 40's, they will tell you if this is complete or what extra items you will need. Very helpful people.
Old 12-19-2009, 06:33 AM
Wiki Edits: 11
wow red ,I'm saving that link,all orig style too.
Old 12-19-2009, 08:16 AM
Thanks that is what I am looking for!
Old 12-19-2009, 08:32 AM
I tell you DBM, if you need parts like that for 37-54 Chevies (and a lot of those parts will work on other GM's as well), Chevs of the 40's has a lot of stuff. And I have always found the staff knowledgeable and helpful.
Case in point is my firewall pad. Called them up and said I was thinking about building my own since all of the factory holes weren't needed but I was going to have to put in new holes where none existed before. I really didn't want to tackle building my own. The lady at Chevs of the 40's said no problem. They were able to have them made with no holes. Done deal.
Prior to that, when I was buying sheetmetal for the car, I called because the drawing wasn't very clear on a particular part I thought I needed. The guy on the phone went and got the part, told me the approximate dimensions, and then proceeded to tell me that most of his customers return them because they really don't fit most people's needs! Cost himself a sale but won a loyal customer.
Chevy II Front Clip Help LuvRod Suspension - Brakes - Steering 33 08-26-2009 03:08 AM
Chevy II front end vrs. Mustang II david6chevy Suspension - Brakes - Steering 2 08-19-2009 07:48 AM
Looking for somebody with SSBC disc kit on a 1966 chevy II Mad_Max Suspension - Brakes - Steering 3 03-06-2006 05:29 PM
The woes of finding sheet metal... Sanspants Body - Exterior 12 03-03-2003 11:39 AM
34 Chevy Sheet Metal Gasser Body - Exterior 2 10-30-2002 12:10 AM
