1948 Coupe Left Handed Lug Threads - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2008, 11:07 AM
I'm attempting to put a set of 94 Lincoln Town Car rims on my 48 Pym 2dr Bus Coupe. The factory car lugs are threaded left on the drivers side, and threaded right on the passengers side. I need to locate a means to convert them as the lug holes are a tad bigger than the Coupes lug bolts. The car has lug bolts that screw out of the hub, rather than lug studs that stay in the hub like modern wheels do when you take the wheel off and on? Getting a tapered conversion lug bolt thats threaded right isn't a problem...it's locating a left handed threaded bolt that I'm wrestling with?
I know I can't be the first to want to put a newer set of wheels on the stock hubs? Any direction I can get is greatly appreciated?
As always, thanks for being so helpful with my project car!
Serpico
Old 04-17-2008, 11:16 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Myself I think I would take the more direct route as those LH threads are a PITA..I would consider taking your hubs and axles to a shop that can drill out and install conventional RH thread studs and be done with it..Much safer and more convenient when you need lug nuts and such..One can go up one size in the stud size with no issues as we do this sort of thing on the race cars on a regular basis..
Sam
Old 04-17-2008, 11:26 AM
48 Coupe Lugs
Thanks for the heads up! I was hoping that I could find a cheaper, less laborous approach but I did not know what you have suggested is possible!
Again, I cannot thank you enough for your kindness in sharing!
Serpico
Old 04-17-2008, 12:30 PM
48 lugs
On My '48 dodge truck, the lugs were actually bolts, so for the driver's side I helicoiled the holes to 1/2" fine Right Hand thread, and used some grade 8 allen bolts from behind with a couple of tack welds on each along with some red loctite. Worked like a charm and cost about $40.00 all in.
Old 04-17-2008, 12:54 PM
31 five window
Last journal entry: grill and rear end
I am with onemoretime.I think he has the best solution to your problem.
Old 04-17-2008, 01:44 PM
Irelands child's Avatar
These probably are pressed in - and if so, should press out fairly easily. Look for a short rounded "nut" on the inside of the drum. I use a big hammer, with the underside of the lug over a piece of pipe to concentrate the hammering around the lug and to not distort the drum face and whang away. Once you get them out it should be a fairly easy task to take one, along with your hole measurements and the actual diameter over the knurls where they press in and have your dealer get out his Dorman book. (Being that old of a car, of course this might not be the way they are installed, but you can hope). There are a lot of choices, with different knurl diameters and lengths. I would only take a couple out at a time - these locate the hub to the drum and if the holes aren't lined up as they were removed you might have to turn the drum.
Irelands child
Old 04-17-2008, 03:10 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I believe he said that he had the screw in lug bolts...not lug nuts and press in studs. That being said...a good machine shop could probably drill hiis threads out and press in some press in type lug studs of the proper size and thread etc.
Old 04-17-2008, 03:17 PM
You're right - I didn't read it well enough - I'm bad
That just makes it a bit easier with screw ins.
Irelands child
Old 04-17-2008, 03:36 PM
Serpico's Question on Left Threaded Lugs
I cannot thank all of you guys enough! I have a solution a local hot rodder shared with me this afternoon that is simple and economical:
He gave me a website for McMaster-Car.com which is a supplier of bolts, nuts, washers, and right at 4000 different items. They supply stud bolts of the exact size that I need. For the left handed threaded side they sell a stud that's left handed thread on one end and right handed on the other!!!
I'm replacing all of mine simply with new stainless steel studs on both sides of the car now and I can use a standard lug nut that threads to the right all the way around. What a savings of labor and money!!!
It's costing me $23.00. She's shipping them to me today and I will have them in hand tomorrow.
www.McMaster-Carr.Com
Telephone 630-833-0300
The website has an on-line catolog!
Old 04-17-2008, 04:00 PM
48ChryslerRodder's Avatar
Stuck in the past.
Better use red Loctite on those left hand threads or some kind of thread locker. When you turn the nuts on to tighten them you can start backing out the left hand threaded studs. The permanent fix is to have them drilled out and studs pressed in from the back. It is a safer alternative and won't come out unexpectedly.
Old 04-17-2008, 04:03 PM
Sounds good - many of us use McMaster Carr for odd ball items. The only caution with stainless - some of it is pretty soft - like about a Grade 2 low carbon steel bolt and really not strong enough for a wheel stud.
Dave W
Irelands child
Old 04-17-2008, 04:20 PM
Wiki Edits: 31
that and with a steel lugnut, it will lock down because of the metal diffrence.
Old 04-20-2008, 08:16 PM
YOU can use 1/2" Grade 8 bolts like I did on my 55pu. I tapped the holes to RH and screwed the bolts from the inside out and tack wlded them and used Ford lug nuts.
41 ford coupe fabricator Hotrodding Basics 13 04-05-2015 09:32 AM
1948 chevy coupe tewdad Transmission - Rearend 4 05-03-2007 07:26 PM
1948 Plymouth 2 Door Coupe BigG815 General Rodding Tech 1 02-26-2007 08:32 PM
1948 Chevy Coupe MN48 Introduce Yourself 2 11-21-2005 07:26 PM
