1948 Ford F1 Project - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 10-04-2007, 03:16 PM
Hi, I just bought a 1948 Ford F1 short bed pickup. The truck has had numerous owners. The body in in great shape. It came with most of the trim and rubber to take care of the exterior. Interior has been slightly modified, and rewired. The guy I bought it from has done very little to it. At some point someone rewired it for a ford 460 Ci engine, and converted it to twelve volts. There are two long battery cables running into the cab for the battery there.
The transmission is a c6 automatic. When the last owner purchased it 6 years ago it was driving and running. Unfortunately it has been sitting since then. So I thought I'd try to fire it up, but it is missing the coil at the moment. I just posted and inquire as to what coil to buy, and what battery, and any wiring advice that may be out there. Thanks, Steve(Stovens)
Old 10-04-2007, 03:21 PM
Notorious's Avatar
Hot rodder, not street rodder!
Is it standard or electronic ignition? Either way, most any old style standard coil should suffice to get it running. It doesn't even have to be from a Ford. Don't waste money on something like an Accel coil, they're junk anyway. If this is a driver that won't see extreme RPMs, a good stock replacement coil will do nicely.
Old 10-04-2007, 03:40 PM
Thanks
Thanks, This will be a fun weekend usable truck, not a show peice or racer. It is a standard ignition.
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
Ford F1 IFS effienut Introduce Yourself 3 01-12-2007 10:32 PM
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 12:37 PM
49 ford f1 wiring diagram jogunne Electrical 7 06-30-2006 07:46 PM
1948 Ford Super Delux LEN ROTHWELL Introduce Yourself 2 01-09-2006 07:47 PM
