Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1949 Chevy Coupe Brake Hardware
Old 08-01-2012, 02:56 PM
matt167 matt167 is offline
Wiki Edits: 31
Best idea is to get the brake parts from a '51-'54 Chevy.. The Huck brake parts are hard to come by and expensive when you find them. 51 Chevy went to Bendix brakes. You only need the backing plates and the front hubs might be different. Everything else is available from the parts store. You can even get self adjuster parts if you wanted
