Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1949 Chevy Coupe Brake Hardware
Old 09-14-2012, 11:55 AM
brian720 brian720 is offline
You have probably found substitute parts, but I have backer plates and all if you don't do a disc conversion. The disc conversion will require changing the master cylinder. Make sure you get a dual chamber which is specific fir front disc, or it may blow out on you. Consider making your own dual cylinder from commercially available parts. The kits tend to be way overpriced and not all that functional.
Good luck,
