Thread Tools Search this Thread share on Facebook
  #1
Old 01-10-2012, 05:04 PM
tbrown8338 tbrown8338 is offline
1949 chevy pickup hood
can someone tell me how the hood should fit on my truck. the hood closes but it look like its setting on top of the fenders. should the edge of the hood be down even with the top of the fenders. my hood bumpers are hitting the fenders so it can't go down any further unless the fenders are spreaded. the fender can't spread because they are connected to the radiator support. please help with adjusting this hood i have tried everthing it know. also the front of the hood is not setting on the hood bumpers.
Register now (free) or login to remove ads
Old 01-12-2012, 01:53 PM
ratrodmiller's Avatar
ratrodmiller ratrodmiller is offline
ratrodder
Last journal entry: 1952 chevy truck
truck cab
hello, What you prolly need to do is shim the front cab mount up about 3/8 of inch also you made need to shim core support up some too.
any more questions feel free to ask i love the trucks!
Old 01-12-2012, 02:46 PM
MARTINSR MARTINSR is online now
Last classified ad: Fifties Chevy passenger...
The hood is probably not back far enough. Remember it's a V shape, so if it is forward just a bit too far the gaps close up. How big is the gap at the rear of the hood to the top of the cowl where it meets up?
Old 01-15-2012, 04:41 PM
1949 chevy hood
probally about a 1/4" gap
Old 01-15-2012, 04:54 PM
1949 chevy pickup doors
yes sir i have a problem with the passenger door gap. at the bottom of this door on the fender side i have a big gap when closed probally 1/2" and about 8" up. i took some measurements in between the door post and on the passanger side it measures about 34" across at the bottom bolt on the hinge. on the drive side it measures about 331/2". i think the outer door post been repaired but it all looks straight. do you have any suggestion on how to correct this. please help!!!! also can you help me with the door rubber on this truck. i ordered some from lmc but it was the wrong rubber and would not let the door close. can you tell me where to get the right rubber from.
Old 01-15-2012, 04:55 PM
1949 chevy hood
can you tell me how to adjust it
Old 01-15-2012, 05:26 PM
ratrodder
door adjustment
Tbrown
I've seen alot of the trucks with your problem. It prolly got hung on something while backing up and the hinge is prolly stretched out.I would try and replace hinges first.
Old 01-15-2012, 05:33 PM
Tbrown
i really don't think it a hing problem the door open and clos fine it's jus the gap at the bottom not the whole gap just about 8" up from the bottom
Old 01-15-2012, 05:38 PM
ratrodder
door adjustment
Well you can slot the hinge out. All three bolt holes that attach to door, slot those holes n hinges and move door back.
Old 01-15-2012, 05:49 PM
ratrodder
weather strip
As far as door rubber I bought mine from classic truck parts in dallas,tx and its real good soft easily conforms and use 3m weather stripping adhesive to install it around doors.
Old 01-15-2012, 05:51 PM
that won't help either. th problem is the gap is perfect on the back side of the door (rear) and it is perfect on the front side until you get close to the bottom. it seem like the front post may be twisted some how i reall don't know
Old 01-15-2012, 05:53 PM
you don't have a part number do you and a picture of how they fit on the doors
Old 01-15-2012, 05:56 PM
ratrodder
doors
Only other alternate fix is cut post lose..when or if floor of cab was replaced the post may have not been straight when new one was welded in. I guess..lol....
Old 01-15-2012, 06:01 PM
ratrodder
weather stripping
The door weather stripping is wedged shaped and it fits perfectly around inside of door panel.right in place where doors skin wraps around door edge.also ill post pic of mine tommor.
Old 01-15-2012, 06:15 PM
ok thatnk's a lot
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1949 chevy pickup hood"
ThreadThread StarterForumRepliesLast Post
adjusting the hood and doors on my 1949 chevy pickuptbrown8338Body - Exterior812-04-2011 11:46 PM
carpet in a 1949 chevy pickuptbrown8338Interior210-29-2011 07:04 AM
1949 chevy pickupsumdaymyownshopGeneral Rodding Tech302-14-2005 08:20 AM
1949 chevy 5 window pickupshradesGeneral Rodding Tech208-04-2004 07:11 PM
Where is the serial # on the 1949 chevy pickup49dreamTransmission - Rearend208-03-2004 10:13 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
