the 1949 chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2008, 10:56 AM
will a 1977 chevy nova sub frame, and rearend work under the 49 body ?
Old 12-28-2008, 03:36 PM
techinspector1's Avatar
Wiki Edits: 326
With a Sawzall, MIG, cutting torch and a good hand grinder, anything will fit anything.
Old 12-28-2008, 08:19 PM
Wiki Edits: 49
Like you were told in your previous post. The 77 Nova sub frame is 61.3" wide and is too wide for the AD trucks without custom backspaced front rims. The rear end track width is 59" which will work just fine.
Old 12-29-2008, 07:19 AM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
That rear axle will need rims that have a back spacing of 3.75 inches or less. Any more and the inside wall of the tire will be rubbing the bed sides on turns.
The front steer Nova suspension is not your best option for that truck. The rear steer nova suspension is what you want but the best solution is an IFS kit.
Help! what frame to put under a chevy 1 1/2 ton truck? Riley Hotrodding Basics 10 02-15-2009 08:15 AM
54' Chevy Truck paddlin4reds Introduce Yourself 3 11-28-2007 01:34 PM
94 chevy truck runnin' like poo! bluesmanjesse Engine 11 11-09-2006 02:54 PM
53 chevy panel truck huligar General Rodding Tech 12 04-27-2006 03:53 AM
questions about 71 chevy truck scrisler Hotrodding Basics 2 09-26-2003 02:29 PM
