1949 Chevy truck gas tank sending unit - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2010, 06:00 PM
Last journal entry: All paint hiccups fixed!
I converted from 6 to 12 volt. I picked up a voltage reducer for the gauges...Does the gas tank sending unit care what the voltage is?
Old 01-14-2010, 11:30 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Since the gauges are stepped down on voltage, the sender will function as it did.
Your fuel gauge is nothing more than an ohm meter. The sender just varies the DC resistance to ground relative to fuel level.
Old 01-15-2010, 09:04 AM
Thanks!
That's exactly the info I was looking for. I didn't want to get the truck back together and discover that I needed to replace the sending unit. Great info, thanks a bunch.
Gas Tank Sending Unit Steve Heyward Hotrodding Basics 3 10-11-2008 04:46 AM
59 chevy gas tank re-location IAMJR59 Hotrodding Basics 10 02-13-2008 07:15 AM
relocating gas tank out of truck cab murrsue General Rodding Tech 6 02-26-2005 01:12 PM
Gas Tank .... problems 63novawagon Body - Exterior 1 04-25-2004 11:26 AM
Need help on dual fuel tank wiring on 86 chevy truck shockers69 Electrical 2 12-26-2003 10:09 PM
