1949 chevy truck radiator replacement..HELP!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2011, 05:21 PM
Last journal entry: All paint hiccups fixed!
I replaced the 235 six with a 350 v8 and auto transmission. Kept the original radiator. I installed a fan shroud and a 16" electric fan to help keep the cooling stable. It's fine as long as I'm rolling down the road, however, if I stop, even to drive through the coffee spot for a cup of joe, it starts getting to the overheating stage. I know the original radiator is 62 years old, and was told it would have to be replaced at some point in time. Now I'm looking at aluminum 3 row, 4 row radiators, custom built three and four row radiators. I saw some on ebay with lifetime guarantees with 3/4" tubes. Any advice on the best way to handle this??? I would very much like to be able to participate in cruises, parades, and wait in line at the drive thru espresso spot without having to turn the engine off to prevent overheating. THANKS IN ADVANCE!
Old 09-12-2011, 05:26 PM
What may very well solve your problem is a proper fan shroud. That is usually the deciding factor on cooling when not in motion while it cools while in motion. Your fan is sucking air from around the sides instead of THROUGH the radiator. A fan shroud around the fan forces it to be pulled THROUGH the radiator.
Old 09-12-2011, 06:00 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
here you go..lot of guys been there done that..if you are on a budget one of the universal radiators will work but you will need to do some modification to the radiator support.
http://www.speedwaymotors.com/Classi...first_answer=1
Sam
Old 09-12-2011, 08:25 PM
Sam - any chance you have any knowledge of what the difference is between the radiator in the link you posted here, and the radiator in the following link? I looked on that site you suggested and they didn't mention how many rows or what the size of the tubes are. Do those details matter?
Thanks
here's the link:
http://cgi.ebay.com/ebaymotors/NEW-A...306b#vi-ilComp
Old 09-12-2011, 08:56 PM
Wiki Edits: 3
details do matter so call the customer service line with your questions..
Sam
Old 09-13-2011, 06:08 AM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
The original honeycomb style radiator will not cool a V8 no matter what fan or shroud you use. It might get you by for awhile but during heavy traffic or summer heat it will fail.
I use a direct replacement "Desert Cooler" style radiator in my 54 and it seems to do a good job cooling the SBC with an electric puller fan.
These radiators are reasonably priced through several sources but I got mine through Classic Parts.com.
Old 09-13-2011, 02:15 PM
Last journal entry: 54 hhr
rad
i also run a desert cooler in my 48 and pusher fan (out of site out of the way) with a s.b.c. i live in phx and cruz all summer. have fun.
1949 chevy truck frame swap Chevy_mn_c1500 Hotrodding Basics 9 07-03-2010 12:59 AM
1949 Chevy truck gas tank sending unit One Month Wonder Electrical 2 01-15-2010 09:04 AM
the 1949 chevy truck 49chevyman Hotrodding Basics 3 12-29-2008 07:19 AM
S-10 Truck Radiator replacement Camarofiend73 Engine 2 10-06-2005 10:12 PM
49 Chevy Truck Windshield Replacement BigMac Body - Exterior 1 08-09-2003 10:43 PM
